Ragsf15e Posted November 22, 2021 Report Posted November 22, 2021 2 hours ago, Shadrach said: I've always wondered what the difference was. Can you shed some light on the weight difference between electric and manual gear? Looks like 13.4lbs… Quote
David Lloyd Posted November 22, 2021 Report Posted November 22, 2021 Notice also the weight of the fuel in that pic. That was for 64 gallons usable at some temperature, I think about 85 degrees. Not the 6 pounds per gallon we were taught but something near adjusted for temp. 1 Quote
PT20J Posted November 22, 2021 Report Posted November 22, 2021 1 hour ago, David Lloyd said: Notice also the weight of the fuel in that pic. That was for 64 gallons usable at some temperature, I think about 85 degrees. Not the 6 pounds per gallon we were taught but something near adjusted for temp. Avgas only weighs 6 lb/gal at 15 deg C. It weighs less per gallon at higher temperatures and more at lower temperatures because a gallon is a unit of volume and the same mass of gasoline expands and contracts with temperature. See attached. My M20J AFM/POH and SMM both specify using 5.85 lb/gal. which would occur at 34 deg C (93.2 deg F). Well, it is hot in Kerrville in the summer... Skip VCF_Aviation-gasoline.pdf 2 Quote
Shadrach Posted November 23, 2021 Report Posted November 23, 2021 (edited) 4 hours ago, David Lloyd said: Notice also the weight of the fuel in that pic. That was for 64 gallons usable at some temperature, I think about 85 degrees. Not the 6 pounds per gallon we were taught but something near adjusted for temp. Perhaps @Ragsf15e’s plane and mine were done on the same 91° day... Edited November 23, 2021 by Shadrach 1 Quote
