‘78 M20J is in annual and mech says the aft-most bell-crank assembly has loose rivets and must be replaced.  It seems to be one that is part of the push/pull assembly for the elevator.  He doesn’t really know how to access this assembly and says it could take lots of hours disassembling things in order to get to it.
Has anyone encountered this before?  Is there an easy solution?
Welcome aboard 1CP.
See if you can start with posting a pic?
This will help assure we are all discussing the same thing.   :)
My aft Rudder bell crank is a little sloppy. Love to change the bearing in it.
But I’ve struggled for a long time to remove it,  and refuse to pay anyone else to figure it out.
I’ve been told there are access holes in the H-Stab for access with a 3/8 socket. However,  I have an early E and I think they forgot to drill the holes in the H-stab rib as mine doesn’t have the holes. I can get the nut off but the bolt hits the side wall…
detailed pictures would be helpful.
-Matt
We replace them often, especially on TKS planes. The rivets get loose. Money has a replacement that is one piece or you can remove yours and replace rivets with hi lock rivets
Thanks Don,
I think the issue is how to get the long -3 bolt  out of the airplane through the tail skin. I’ve had the nut off but the bolt hits the sidewall.
-Matt
4 minutes ago, N91CP said:
We're going out to the shop today.  I'll see if I can get a photo or two.
Yours should have holes in the two inner most ribs of the horizontal stab.  With the nut removed you should be able to work the bolt out passing the head of the bolt into the clearance hole in the rib.  Before disassembling it take pictures and note the location of any washers slipped between the bellcranks and the 3 mounting brackets. Mooney is famous for adding them.
Reassembly and slipping and washers back in place can be a challenge, but it’s not impossible.
Working on an Ovation today and took some pictures and a video.  The elevator walking began in the tailcone has loose huck bolts.  In the background you can see the bolt clearance hole in the stabilizer butt rib.
On 8/10/2021 at 1:13 AM, carusoam said:
Clarence,
Was the owner aware of the issue, or something you found during other maintenance?
Anthony,
We found it during a routine 100 hour inspection, our first on the plane.  Lots of expensive discoveries.
20 hours ago, M20Doc said:
Anthony,
Clarence,
Are you moving the left and right elevators in opposite directions in the video? Is that how you found it?
Skip
2 hours ago, PT20J said:
Clarence,
Skip
Skip,
Just investigating some minor free play at the elevator trailing edge with a gentle wiggle.  We just followed along until we found it.
Interesting...
There is no visible, exposed thread from the Huck bolt on those collars. I am not sure if that's how Huck's are designed but there's a reason why (almost) everyone in aerospace uses Hi-Lites.
The rudder walking beam must be under less/different stress as it’s held together with AN470AD4 rivets.
