JoeM Posted July 26, 2021 Report Posted July 26, 2021 Would appreciate guidance how to remove PC rudder servo that sits under the battery. Search forums without success. Looks like the back nut is inside the belly pan....Correct? Thanks..... Quote
0TreeLemur Posted July 26, 2021 Report Posted July 26, 2021 1 hour ago, JoeM said: Would appreciate guidance how to remove PC rudder servo that sits under the battery. Search forums without success. Looks like the back nut is inside the belly pan....Correct? Thanks..... Yes. Access through the belly. Do you have elevator servos? If so, I'm interested & looking for a spare set with intact membranes. Quote
