Does anyone have tech data or know the procedure for gapping the points on a shower of sparks system for a 67F model.  That part of my maintenance manual is missing.
Thanks
Thanks
In the Downloads section under engines the SoS manual is there.
Once you set the gap, pull the plugs, ground one plug and connect the plug wire, rotate the prop to TDC on that cylinder to observe a strong shower of sparks. If no shower, check the retard p-lead on the left mag. In my case I had a short on that p-lead at the mag where it screws in… I thought I had a SOS issue when it was the retard p-lead.
