MooneyAcolyte Posted December 2, 2020 Report Posted December 2, 2020 A change of user name is due: wannebeMooniac signs off as I picked up my M20J today. Thanks to you all for your insights and wisdom so far. 13
tmo Posted December 2, 2020 Report Posted December 2, 2020 Keeping it HB-reg while living in the Netherlands? I was under the impression that PH was one of the more reasonable EASA registries, much more so than HB.
Greg Ellis Posted December 2, 2020 Report Posted December 2, 2020 1 hour ago, MooneyRookie said: A change of user name is due: wannebeMooniac signs off as I picked up my M20J today. Thanks to you all for your insights and wisdom so far. Looks like in a short while you will be changing from Rookie to....well....whatever the next level up is. 2
rbridges Posted December 2, 2020 Report Posted December 2, 2020 Just don't change it to LandedgearupRookie. 1 3
carusoam Posted December 2, 2020 Report Posted December 2, 2020 Way to go Wannabe! The mask is off... The wings are on... Yay! Best regards, -a- 1
MooneyAcolyte Posted December 7, 2020 Author Report Posted December 7, 2020 On 12/2/2020 at 3:59 PM, Greg Ellis said: Looks like in a short while you will be changing from Rookie to....well....whatever the next level up is. Working on it. Thanks.
MooneyAcolyte Posted December 7, 2020 Author Report Posted December 7, 2020 On 12/2/2020 at 3:02 PM, tmo said: Keeping it HB-reg while living in the Netherlands? I was under the impression that PH was one of the more reasonable EASA registries, much more so than HB. Yes, I am planning to switch. It works better language wise also between the shop and the authorities. 1
MooneyAcolyte Posted December 7, 2020 Author Report Posted December 7, 2020 On 12/2/2020 at 2:57 PM, Tim Jodice said: Your going to love it! Thanks. Already am.
