all4thekidz Posted November 10, 2020 Report Posted November 10, 2020 I am looking for as many photos of the electric gear configuration both under the belly and inside behind the panel where the Manual gear lever is positioned. Does the manual gear lever have a bracket or is it connected to the tubing? Additionally I have seen different layouts of the spring and lock mechanism to engage the manual gear. Additionally I have a question about the nose gear. I have replaced the bushings and I still have play where the bolt connects the steering mechanism to the gear. It appears the hole that is goes through has been Wallered out. Is there a fix to this or do I have to replace the gear? Thanks TODD Quote
carusoam Posted November 11, 2020 Report Posted November 11, 2020 9 hours ago, all4thekidz said: I am looking for as many photos of the electric gear configuration both under the belly and inside behind the panel where the Manual gear lever is positioned. Does the manual gear lever have a bracket or is it connected to the tubing? Additionally I have seen different layouts of the spring and lock mechanism to engage the manual gear. Additionally I have a question about the nose gear. I have replaced the bushings and I still have play where the bolt connects the steering mechanism to the gear. It appears the hole that is goes through has been Wallered out. Is there a fix to this or do I have to replace the gear? Thanks TODD Todd, This is a great question for Dan at Lasar... They have the OH’d gear units and Dan can walk you through the steps of what you have, and what you need... When it comes to worn steering gear parts... Dan is the man... Probably won’t make a difference if it is electric or manual... Best regards, -a- Quote
