201Steve Posted May 18, 2020 Report Posted May 18, 2020 I did a wet wash on Saturday and just for fun, I shoved my finger into the sidewall at the floor/ base of the rear seat to check for moisture and there was some. The sealant on the outside of my windows is looking like it's seen better days. What are you guys using for sealant on the outside of windows/windshield? Quote
ArtVandelay Posted May 18, 2020 Report Posted May 18, 2020 PRC, I think it’s the same thing they used on fuel tank inspection panels. 1 Quote
MB65E Posted May 18, 2020 Report Posted May 18, 2020 Prc 1425 b 1/2 is black and I use it on windows. It is not fuel tank sealant. -Matt 1 Quote
201Steve Posted May 18, 2020 Author Report Posted May 18, 2020 On 5/18/2020 at 9:50 PM, MB65E said: Prc 1425 b 1/2 is black and I use it on windows. It is not fuel tank sealant. -Matt Expand A quick search looks like it only comes in black. Have you heard of the same in white? Also, would you say one tube is enough for all windows and windshield? Quote
MB65E Posted May 19, 2020 Report Posted May 19, 2020 One tube should work if you have nice thin gaps. I have only seen it in black. It’s good stuff -Matt Quote
Old Chub Posted May 19, 2020 Report Posted May 19, 2020 Be sure and tape off everywhere you don't want the sealant. Let slightly set before dipping your finger in dishwashing liquid to smooth our the joint. Pull tapes prior to full set so you can clean up any misses. After full cure wash with water to remove all remaining dishwashing liquid. This makes a very nice looking smooth sealed joint. 3 Quote
carusoam Posted May 19, 2020 Report Posted May 19, 2020 Read what old chub is saying closely... the description is spot-on for making a nice finish... the soap is a lubricant... Also works well with silicone around the bathtub... and sealing walls in a pharma clean room environment... +1 PRC is the right material to use... that is what was put in there originally... Or... you might be considering taking the windows out and replacing them.... you will want the PRC remover to do that... PP thoughts only, not a mechanic... Best regards, -a- 2 Quote
201Steve Posted May 21, 2020 Author Report Posted May 21, 2020 Photo of the product. Do I need to buy an applicator gun/bottle or just use a spatula? Quote
MB65E Posted May 21, 2020 Report Posted May 21, 2020 See if you can get it in the tube. It will be better for your application. They make it in 6oz tubes. -Matt 1 Quote
