Neshi Posted May 13, 2020 Report Posted May 13, 2020 Starting my panel upgrade Adding installing 2 G5s and normalizing the 6 pack. Only wish I could have gotten the wife to let me buy a 650 Before The gut The Plan
StevenL757 Posted May 13, 2020 Report Posted May 13, 2020 Looking good so far. Why not lose the engine gauges on the right and add the EDM900 as Primary instead? You can put the 900 in a landscape position and slide it left (along with your transponder) closer to the 430 stack. You’d be able to see both of them easier, rescue some panel space, and clean up the look even more. Steve 3
Neshi Posted May 13, 2020 Author Report Posted May 13, 2020 24 minutes ago, StevenL757 said: Looking good so far. Why not lose the engine gauges on the right and add the EDM900 as Primary instead? You can put the 900 in a landscape position and slide it left (along with your transponder) closer to the 430 stack. You’d be able to see both of them easier, rescue some panel space, and clean up the look even more. Steve That's next years plan the wife will only approve so much at one time.
StevenL757 Posted May 13, 2020 Report Posted May 13, 2020 With respect, you may want to explain to her that with the trade in of your existing instruments, plus what you’re probably paying for the 830, you’re extremely close to the 900 cost-wise. The labor you’ll spend doing it later will far exceed doing it now “while you’re in there”. Financially, it doesn’t make sense to do it after-the-fact. 3 2
robert7467 Posted May 13, 2020 Report Posted May 13, 2020 I rough cut my panel, used nuts and screws to bolt the old panel to the new for the outline and shock mount holes and the repositioned and clamped the panel and used a router for the cutouts. For the zero degree tilt, I used the old shock mounts and attached the angle aluminum. Using the old as a template, all my shock mount screws were perfectly aligned.The left empty hole is for the D2 panel mount and the big hole on the right is for the 496. The 2 holes below that are from removed Davtron DVOR and temp gauge. I am filling those with USB plugs. Should have her buttoned up today and I can send a pic of the completed panel.a router and the old panel as a template goes a long way. Use the table router with a flush bit and fee hand it. 1
robert7467 Posted May 13, 2020 Report Posted May 13, 2020 Oh, and when you are going your cutouts flip and clam the old panel so its flush.
gsxrpilot Posted May 13, 2020 Report Posted May 13, 2020 19 hours ago, Neshi said: The Plan It does look nice, but from a financial standpoint, not the way I would have done things. The 430 has trade-in value today but that value drops every day. So I'd trade it in on an IFD440 before the value drops any further... The IFD also comes with $0 install cost. Echoing what @StevenL757 said, you can either do the engine monitor twice, and cut the right side panel twice, or do it once. Sell the factory gauges and make up the difference. There is no difference in cost if you put in the G5's today or next year. So for me, those would wait. I would still cut a new panel for the left side to arrange the steam gauges into a standard six pack pattern. Just make sure you leave room to enlarge the holes to put in the G5's when you're ready. You'll be able to install them later without cutting a new panel and without even removing the panel. Anyway, just my $0.02. The only thing worse then spending hard earned money, is spending it twice. 4
Neshi Posted May 13, 2020 Author Report Posted May 13, 2020 23 minutes ago, gsxrpilot said: It does look nice, but from a financial standpoint, not the way I would have done things. The 430 has trade-in value today but that value drops every day. So I'd trade it in on an IFD440 before the value drops any further... The IFD also comes with $0 install cost. Echoing what @StevenL757 said, you can either do the engine monitor twice, and cut the right side panel twice, or do it once. Sell the factory gauges and make up the difference. There is no difference in cost if you put in the G5's today or next year. So for me, those would wait. I would still cut a new panel for the left side to arrange the steam gauges into a standard six pack pattern. Just make sure you leave room to enlarge the holes to put in the G5's when you're ready. You'll be able to install them later without cutting a new panel and without even removing the panel. Anyway, just my $0.02. The only thing worse then spending hard earned money, is spending it twice. I would agree with that if everything was 100% working. The DG needed to be replaced. So that was one G5 and I tossed in the other as I've had 6 vacuum failures in 5 years since I started flying 2 in while ifr. (Not all the same plane or owner just my bad luck to have the penny drop while I'm flying) The EDM 730 came with the aircraft upgrading to a 900/930 is a want not a need for now and I'm scheduling for next years budget with a 650xi or what ever is coming out between now and then. Maybe I'm just odd but I don't like the 440. The hardware is nice and it does everything the Garmin units do and cheaper. But every time I flew an aircraft with one it was always 10 seconds of thinking be for an action. With the GTN & GNS units my fingers just work. 1
gsxrpilot Posted May 13, 2020 Report Posted May 13, 2020 Makes sense... and it's your airplane. It sounds like you've thought it through.
robert7467 Posted May 14, 2020 Report Posted May 14, 2020 It's an old airplane, I just installed a 420 and made my plane more capable than it already was, but its "certified".... I just installed a bunch of old, crusty avionics, but before I couldn't shoot an ILS, so its worth it... Good wiring and decent avionics goes a long way. I am sure as H not going to dump 100k in avionics in a legacy plane. One man's trash is another man's . treasure! I am just thankful that I dont hear noise in my radios and I can shoot and ILS and GPS approach. I have dealt with my fair share of old crusty wiring, power issues, crackling noise on the intercom. Now that I have good wiring, I can upgrade as I go, as I can afford. One piece at a time... 3
tmo Posted May 14, 2020 Report Posted May 14, 2020 11 hours ago, gsxrpilot said: The IFD also comes with $0 install cost. IIF the antenna and cable is already WAAS, otherwise that gets to be replaced; that said, yes, from what I see, as trivial of an upgrade as can be, with a lot of "bang for buck". 1
Neshi Posted May 16, 2020 Author Report Posted May 16, 2020 (edited) paint next Edited May 16, 2020 by Neshi 1
Neshi Posted June 5, 2020 Author Report Posted June 5, 2020 Install is coming along. Fathers day gift to myself added 650xi and Garmin 345. 4 1
carusoam Posted June 6, 2020 Report Posted June 6, 2020 Fantastic Father’s Day gift for the man who has a Mooney/forever-plane.... Best regards, -a-
Hoeschen Posted June 6, 2020 Report Posted June 6, 2020 isn’t it nuts how small the HSI display is on a G5 compared to a standard 3-1/8” HSI. the actual round dial looks like half the size. Sent from my iPad using Tapatalk
Neshi Posted June 6, 2020 Author Report Posted June 6, 2020 isn’t it nuts how small the HSI display is on a G5 compared to a standard 3-1/8” HSI. the actual round dial looks like half the size. Sent from my iPad using Tapatalk Never noticed it but now you say it I can’t not see. Sent from my iPhone using Tapatalk
Mscheuer Posted June 8, 2020 Report Posted June 8, 2020 Hi Matt, I just couldn't help myself. Thank you for flying with our original PMA8000BT (circa 2006), with those beautiful G5's at that GTN, I could resist to show you what the "ultimate panel" would look like. Sincerely, Mark 1
StevenL757 Posted June 8, 2020 Report Posted June 8, 2020 @Neshi, I think you and I are in the same shop at the same time... I just checked in with "Rick and Company" this morning for round 2 of upgrades. Your panel looks amazing. Saw it all lit up earlier this morning, and it really does look impressive. :-) I'm based across the field, so if you need anything, let me know. I'm over there a few times a week. Not sure where you're based... Steve
Neshi Posted June 8, 2020 Author Report Posted June 8, 2020 @StevenL757, Nice what are they doing for you? I'm normally over on the west side sheltair tiedowns.
StevenL757 Posted June 8, 2020 Report Posted June 8, 2020 Existing panel below...I’ll be doing: Trade G500, upgrade to G500Txi New GCU485 PFD Controller Trade GTN750 for GTN750xi Remove KX165, install GTN650xi Trade JPI EDM900 for EDM930 Add GSB15 USB charger underneath audio panel
Neshi Posted June 16, 2020 Author Report Posted June 16, 2020 upgrade complete did my test flight had a few adjustments to the autopilot every thing else is great. Rick and his team went above and beyond in completing the upgrade repairing little things not in the contract.
carusoam Posted June 17, 2020 Report Posted June 17, 2020 Bummer.... Matt/Neshi... you have to post the video in youtube and copy the link here.... That way everyone can see it... Best regards, -a-
