Something odd happened on my flight yesterday that I’m thinking is an indication issue but wanted to get the collective wisdom of the folks here.  I was climbing from sea level to 19k ft in a constant climb and my oil temp was pegged at 190 the entire way up (which is a little cool for a warm summer day in climb).
As soon as I leveled off the temp went from 190 to about 207 in a matter of 1-2 minutes.  Later in the flight the temp settled down to about 203-204.  I know these temps are warmer than they should be but up in the flight levels it’s not abnormal for me to see temps around 200.
Any ideas it has this happened to others?  This is the first time in about 500 hrs of flying this plane this has happened…
