I emailed the factory with my serial number and they emailed mine to me. You can import the PDF from there.
Sent from my Pixel 3 using Tapatalk
1 hour ago, Lukon said:
Does anybody have a PDF or something I can stick in ForeFlight?
There are several in the Download section here, there us even a 1965 version I think.
Look around and grab a copy of the latest one you can find, too--it has much better (and more!) information than is in the 1965 version. Just don't try to use the higher V-speeds.
65 OM for Arrow documents...
76 POH for performance data...
As Hank mentions use caution on speed limitations... there is a change of structure and limitations on some things...
  • 3 weeks later...
