I never found one.  I had a 201 which worked close enough for my needs.  I always kept the paper 205 in the plane but didn’t go to the trouble of scanning it myself.
If you have a paper copy... it isn’t too hard to use your I-device to make a good e-copy...
If you need to start from scratch, it is best to start with getting a copy from Mooney, through the MSC system...
