Dream to fly Posted December 30, 2018 Report Posted December 30, 2018 My 2 G5s arrived today. It was a couple of days late because of being on the naughty list. Apparently when the wife says plow the driveway it's not just for her but FedEx too. I am stupid excited to get this all done and start flying but I'm starting to wonder if I should sell my engine at 1400 hrs and get a new one. I've literally done everything else except for an internal detail cleaning of the wings and fuselage. Any ideas? Sent from my E6810 using Tapatalk 1 Quote
RLCarter Posted December 30, 2018 Report Posted December 30, 2018 Maybe an internal detail cleaning of the wings and fuselage? 1 2 Quote
Mcstealth Posted December 30, 2018 Report Posted December 30, 2018 Without pictures it hasn't happened. Congratulations Quote
Dream to fly Posted December 30, 2018 Author Report Posted December 30, 2018 Without pictures it hasn't happened. Congratulations Working on it.... Sent from my E6810 using Tapatalk Quote
Dream to fly Posted January 14, 2019 Author Report Posted January 14, 2019 Without pictures it hasn't happened. Congratulations Well?Sent from my E6810 using Tapatalk 3 Quote
Guest Posted January 14, 2019 Report Posted January 14, 2019 1 hour ago, Dream to fly said: Well? Sent from my E6810 using Tapatalk Nice! What’s going in the empty hole? Clarence Quote
MBDiagMan Posted January 14, 2019 Report Posted January 14, 2019 Sell engine at 1400 hours? Is it making metal? Low compression? Quote
Dream to fly Posted January 14, 2019 Author Report Posted January 14, 2019 Nice! What’s going in the empty hole? Clarence The old Brittain turn bank. Still using wing levelerSent from my E6810 using Tapatalk Quote
Dream to fly Posted January 14, 2019 Author Report Posted January 14, 2019 Sell engine at 1400 hours? Is it making metal? Low compression? No. Just thinking about going all in and either making it new or a rocket.Sent from my E6810 using Tapatalk Quote
MBDiagMan Posted January 14, 2019 Report Posted January 14, 2019 If the engine is in good shape at 1400 hours, overhauling is completely unnecessary. Worse yet, a new engine is statistically less reliable than a 1400 hour engine in known good condition. 2 Quote
Dream to fly Posted January 14, 2019 Author Report Posted January 14, 2019 If the engine is in good shape at 1400 hours, overhauling is completely unnecessary. Worse yet, a new engine is statistically less reliable than a 1400 hour engine in known good condition. I guess my thinking is this plane has had all the majors repaired or replaced and the last thing is the engine. I needed this plane to work when I got it and I done nothing but fix it. So when I'm done it needs to fly. I was just trying to beat the odds.Sent from my E6810 using Tapatalk Quote
MBDiagMan Posted January 14, 2019 Report Posted January 14, 2019 I understand the urge, but this is a good time to apply the old “if it ain’t broke don’t fix it” adage as far as the engine goes. Statistically there are more engine failures in the first few hundred hours than in the 1000 to TBO range. In fact I think I am correct in saying that there are statistically less failures even after TBO, there are lower odds of a failure than an overhauled engine. If I am wrong I expect to be corrected shortly. Quote
Marauder Posted January 14, 2019 Report Posted January 14, 2019 (edited) 8 hours ago, Dream to fly said: I guess my thinking is this plane has had all the majors repaired or replaced and the last thing is the engine. I needed this plane to work when I got it and I done nothing but fix it. So when I'm done it needs to fly. I was just trying to beat the odds. Sent from my E6810 using Tapatalk Anyone who has bought a plane was or is in your situation at one time or another. I flying was for business in the 1990s and dispatch time was critical. If I had to endure a 6 week episode that I did recently for my brake issues, I would have been pretty beaten down by it. Even the airlines, with their constant maintenance schedules still have things pop up and require a plane to be taken off of the line. Once you get past the challenges you are dealing with now, it is just a matter of staying proactive on things that could give you an issue later. It’ll get better. Hang in there. You’ll look back at all of this as a sense of accomplishment and all will be a fond memory, not the agony it is now. Sent from my iPad using Tapatalk Pro Edited January 14, 2019 by Marauder 1 Quote
Dream to fly Posted January 14, 2019 Author Report Posted January 14, 2019 Anyone who has bought a plane was or is in your situation at one time or another. I flying was for business in the 1990s and dispatch time was critical. If I had to endure a 6 week episode that I did recently for my brake issues, I would have been pretty beaten down by it.Even the airlines, with their constant maintenance schedules still have things pop up and require a plane to be taken off of the line. Once you get past the challenges you are dealing with now, it is just a matter of staying proactive on things that could give you an issue later. It’ll get better. Hang in there. You’ll look back at all of this as a sense of accomplishment and all we be a fond memory, not the agony it is now.Sent from my iPad using Tapatalk ProI hope so.Sent from my E6810 using Tapatalk 1 Quote
jaylw314 Posted January 14, 2019 Report Posted January 14, 2019 2 hours ago, Dream to fly said: I guess my thinking is this plane has had all the majors repaired or replaced and the last thing is the engine. I needed this plane to work when I got it and I done nothing but fix it. So when I'm done it needs to fly. I was just trying to beat the odds. Sent from my E6810 using Tapatalk Maybe another way to think of @MBDiagMan's suggestion is that most of the theoretical failures due to TBO are going to be long, gradual degradation in performance rather than catastrophic failures. As such, it makes sense to wait until your engine is telling you a problem, and then wait until it's no longer tolerable. If your cam and lifters are wearing, you'll see it in oil analyses, then engine performance as opposed to in-flight engine failure. Obviously, this doesn't account for problems NOT caused by time-since-overhaul, but that would be a different line of thinking. 1 Quote
