merrja Posted October 1, 2018 Report Posted October 1, 2018 Hi All, Anyone have issues with the over voltage light coming on more and more frequently? It resets if I pull and reset the field breaker. Thanks! Jim Quote
ArtVandelay Posted October 1, 2018 Report Posted October 1, 2018 Hi All, Anyone have issues with the over voltage light coming on more and more frequently? It resets if I pull and reset the field breaker. Thanks! Jim Verify it’s not an annunciation error first. Quote
Mooneymite Posted October 2, 2018 Report Posted October 2, 2018 1 hour ago, merrja said: Anyone have issues with the over voltage light coming on more and more frequently? It resets if I pull and reset the field breaker. Thanks! Jim I'm not sure how your 68 F is electrically configured, but the over-voltage light on my '74 C came on a couple of times after engine start. I reset it by turning the master off, then back on. Because I was sure that my voltage regulator was going bad, I bought a voltage regulator and put in in my baggage compartment....just in case. It's still there. Apparently the new regulator scared the installed voltage regulator into behaving. I wasn't able to determine any cause, or cure. Good luck. Electrical gremlins can be fickle. Quote
65C_flier Posted October 2, 2018 Report Posted October 2, 2018 I had an over voltage light coming on intermittently. After replacing the zeftronics (and not fixing the problem) we found it was a frayed field wire on the alternator. Quote
N201MKTurbo Posted October 2, 2018 Report Posted October 2, 2018 I just had this problem. I tried everything. Contacts on master, new brushes, inspected and tightened field wires. I was too cheap to buy a new regulator. Nothing fixed it until I bought a new regulator. Quote
