TTaylor Posted January 3, 2019 Report Share Posted January 3, 2019 On 1/2/2019 at 6:18 AM, Michel02 said: last question, where are those servo so many door thank Michel The servo are usually near the battery in the aft fuselage. Access through the battery door behind the wing. It is normally a one servo system (the rudder and ailerons are slaved together with springs in early 1970's Mooney's) that approximates two axis. Quote Link to comment Share on other sites More sharing options...
kerry Posted January 4, 2019 Report Share Posted January 4, 2019 My servo is in the right wing. Access panel is in front of the aileron. Quote Link to comment Share on other sites More sharing options...
Michel02 Posted January 5, 2019 Report Share Posted January 5, 2019 thank you for help. Michel Quote Link to comment Share on other sites More sharing options...
Michel02 Posted January 5, 2019 Report Share Posted January 5, 2019 oup thanks Quote Link to comment Share on other sites More sharing options...
AlexLev Posted April 8, 2019 Author Report Share Posted April 8, 2019 @kerry - finally talked to an avionics guy about adjusting the A/P from the controller. He says it would be tough to do without an extension of sorts for the voltmeter to plug into the controller. Any thoughts/how to get one or who could help answer these questions? Have you ever had your controller inputs adjusted? Michael Ritterbush hasn't gotten back to me, but I'll try emailing him one more time. Quote Link to comment Share on other sites More sharing options...
kerry Posted April 9, 2019 Report Share Posted April 9, 2019 Be persistent in contacting Michael Ritterbush. Sometimes it take a half dozen times before he responds. I've made adjustment while flying. e.g- Rate of turn and heading. It would probably be easier if someone had the controls while another person is making the adjustments. I've done adjustments by myself while flying. Quote Link to comment Share on other sites More sharing options...
Big Dog Posted April 27, 2020 Report Share Posted April 27, 2020 I have a Pathfinder to a in my Cessna 182. I put in a Avedyn 540 and had Michael rework the Turn Coordinator. I had Affordable Avionics in Chino put in the Avedyn 540. The auto pilot does not work. When I put it on the heading it slams to one side. Does anyone know somebody that does work on these? Quote Link to comment Share on other sites More sharing options...
kerry Posted April 29, 2020 Report Share Posted April 29, 2020 I would start by unplugging all the connectors and clean them real well. Quote Link to comment Share on other sites More sharing options...
LANCECASPER Posted April 30, 2020 Report Share Posted April 30, 2020 On 4/27/2020 at 4:07 PM, Big Dog said: I have a Pathfinder to a in my Cessna 182. I put in a Avedyn 540 and had Michael rework the Turn Coordinator. I had Affordable Avionics in Chino put in the Avedyn 540. The auto pilot does not work. When I put it on the heading it slams to one side. Does anyone know somebody that does work on these? I would start here: https://webairconsulting.com/ Quote Link to comment Share on other sites More sharing options...
brndiar Posted April 30, 2020 Report Share Posted April 30, 2020 Hi. Now I am confused. My is 1977 M20C, with P2A Autopilot, without modification. Though system is electric, my P2A Directional Gyro NEEDS VACUUM. m PatrFinder P2A.pdf 1 Quote Link to comment Share on other sites More sharing options...
carusoam Posted April 30, 2020 Report Share Posted April 30, 2020 MS Austria calling in with pics and a manual!!! Way to go Brndiar! Go MS! Best regards, -a- Quote Link to comment Share on other sites More sharing options...
kerry Posted April 30, 2020 Report Share Posted April 30, 2020 Yes, the DG is operated by vacuum but the DG heading bug output to the autopilot controller is electric. In a prior post someone mentioned when they engage the AP it banks hard to one side. I would think this is an electrical issue. Either a bad electric plug connection or a problem with the TC. With my P2A I've had to clean the plug terminals at the back of the AP controller on more than one occasion to get my AP to work correctly. Quote Link to comment Share on other sites More sharing options...
brndiar Posted April 30, 2020 Report Share Posted April 30, 2020 Quote Link to comment Share on other sites More sharing options...
brndiar Posted April 30, 2020 Report Share Posted April 30, 2020 1 hour ago, kerry said: Yes, the DG is operated by vacuum but the DG heading bug output to the autopilot controller is electric. In a prior post someone mentioned when they engage the AP it banks hard to one side. I would think this is an electrical issue. Either a bad electric plug connection or a problem with the TC. With my P2A I've had to clean the plug terminals at the back of the AP controller on more than one occasion to get my AP to work correctly. I had similar Problem. In my case 1 Servo was not working + somewhere was kabel defekt. lg,m Quote Link to comment Share on other sites More sharing options...
wcb Posted April 30, 2020 Report Share Posted April 30, 2020 I removed mine... if anyone is looking for spare parts (send me a picture of what you are looking for and I will see what i have). I have no idea what works and doesn't work with it. Quote Link to comment Share on other sites More sharing options...
kerry Posted April 30, 2020 Report Share Posted April 30, 2020 8 minutes ago, wcb said: I removed mine... if anyone is looking for spare parts (send me a picture of what you are looking for and I will see what i have). I have no idea what works and doesn't work with it. Do you have any of the Pathfinder parts for pitch function? Quote Link to comment Share on other sites More sharing options...
wcb Posted April 30, 2020 Report Share Posted April 30, 2020 Send me a picture of what you are looking for. I do not know what was pitch etc. Quote Link to comment Share on other sites More sharing options...
brndiar Posted August 6, 2020 Report Share Posted August 6, 2020 Hi I am looking for Amplifier Servo for my Pathfinder P2A autopilot. There is short circuit in my Servo (the fuse pops up after connection). Contacted my electronics shop, they can´t fix it. After last reparation my Pathfinder P2A autopilot worked for my cca 150 hours. Eventual don´t you have idea what could be wrong and how to repair it? Thanks for any help lg, milos Quote Link to comment Share on other sites More sharing options...
wcb Posted August 6, 2020 Report Share Posted August 6, 2020 I have it and do not know if it is working or not Quote Link to comment Share on other sites More sharing options...
brndiar Posted August 6, 2020 Report Share Posted August 6, 2020 Ok, my is not working anyway. Would you send it? I would buy it from you anyway. Thanks forward, Milos Quote Link to comment Share on other sites More sharing options...
brndiar Posted September 13, 2020 Report Share Posted September 13, 2020 Please, does anybody have the wiring diagram or the installation manual or something helpful for troubleshooting for vintage Pathfinder 2A autopilot?thank for any help. lg, m Quote Link to comment Share on other sites More sharing options...
