Igor_U Posted January 24, 2018 Report Posted January 24, 2018 On 1/24/2018 at 5:41 AM, FBV said: Per my layout, my vacuum driven DG is really deep and it hit the control column behind the panel. So I either had to revert to square one or settle for a non standard 6-pack layout. I decided on the later. I’m in way deep on the existing panel and have no time to change the layout again. Yes, had lots of trimming to do. Dremel, snips, nibblers are all required tools. Sent from my iPhone using Tapatalk Expand Yes, That's what I though it might be the case. Your DG must be deeper then others as I've seen quite a few photos of panels with vacuum DGs below AI. On the other hand, when I'll do my panel, this might not be an issue for me as I'd like to install second G5/HSI at that location. I see you got a vertical faceplate for Accutrak which is great; I meant to mention that they might want to ask them about it. Did you try to place AcuTrak horizontally, in top right corner where Landing gear lights are? That would be my preferred location but it seems very tight, especially considering structure under panel. I would like to try that, though. Location you've chosen is not bad at all and I'll seriously consider it in my layout. Regards, Quote
FBV Posted January 24, 2018 Author Report Posted January 24, 2018 On 1/24/2018 at 12:14 PM, Igor_U said: Yes, That's what I though it might be the case. Your DG must be deeper then others as I've seen quite a few photos of panels with vacuum DGs below AI. On the other hand, when I'll do my panel, this might not be an issue for me as I'd like to install second G5/HSI at that location. I see you got a vertical faceplate for Accutrak which is great; I meant to mention that they might want to ask them about it. Did you try to place AcuTrak horizontally, in top right corner where Landing gear lights are? That would be my preferred location but it seems very tight, especially considering structure under panel. I would like to try that, though. Location you've chosen is not bad at all and I'll seriously consider it in my layout. Regards, Yeah, I wanted the accutrak where the gear lights are. Would not fit. The sub panel had to be trimmed a lot just for the lights and vacuum gauge. The angle of the left panel mounted on rubber shocks is critical to making things fit too. Sent from my iPhone using Tapatalk Quote
tony Posted January 25, 2018 Report Posted January 25, 2018 On 1/24/2018 at 5:41 AM, FBV said: Per my layout, my vacuum driven DG is really deep and it hit the control column behind the panel. So I either had to revert to square one or settle for a non standard 6-pack layout. I decided on the later. I’m in way deep on the existing panel and have no time to change the layout again. Yes, had lots of trimming to do. Dremel, snips, nibblers are all required tools. Sent from my iPhone using Tapatalk Expand I had the exact same problem and came to the same conclusion as you. I was way to deep into it to change. I was bother by that decision for a while but since I only fly one airplane it became a non issue. Quote
bcwiseguy Posted January 27, 2018 Report Posted January 27, 2018 On 4/27/2017 at 9:37 PM, FBV said: Here is a friend of mine that has a 1 piece panel in his F. This is the look I was going for. Sent from my iPhone using Tapatalk Expand That's a beautiful panel. When I had my 1966 E (N9278M) I had a panel redo and I installed some EI Gauges. I enjoyed my new panel so much more than the original panel. This was back in 2000. Oh how times have changed since then. GPS/NAV/Comms are commonplace. I had an Apollo Loran C system I used and really liked. Quote
bcwiseguy Posted January 27, 2018 Report Posted January 27, 2018 On 4/27/2017 at 9:37 PM, FBV said: Here is a friend of mine that has a 1 piece panel in his F. This is the look I was going for. Sent from my iPhone using Tapatalk Expand On 4/27/2017 at 9:37 PM, FBV said: Expand That's a beautiful panel. When I had my 1966 E (N9278M) I had a panel redo and I installed some EI Gauges. I enjoyed my new panel so much more than the original panel. This was back in 2000. Oh how times have changed since then. GPS/NAV/Comms are commonplace. I had an Apollo Loran C system I used and really liked. Quote
FBV Posted February 16, 2018 Author Report Posted February 16, 2018 Finished the panel. It’s been about a year of planning and probably 200 hours of work. First flight yesterday was true gratification.Sent from my iPhone using Tapatalk 4 Quote
carusoam Posted February 16, 2018 Report Posted February 16, 2018 Nicely done, FBV! Best regards, -a- Quote
lithium366 Posted March 1, 2021 Report Posted March 1, 2021 On 1/27/2018 at 3:41 PM, bcwiseguy said: That's a beautiful panel. When I had my 1966 E (N9278M) I had a panel redo and I installed some EI Gauges. I enjoyed my new panel so much more than the original panel. This was back in 2000. Oh how times have changed since then. GPS/NAV/Comms are commonplace. I had an Apollo Loran C system I used and really liked. Expand Do you know what kind of sun vizors N9278M had or maybe have more pictures? I own this airplane now and it doesn’t have sun visors Quote
bcwiseguy Posted March 1, 2021 Report Posted March 1, 2021 Attached is a small picture showing the sun visors that were installed when I had the airplane. It's not a great pic but it's the only one I have left after a hdd crash. I don't really remember much about the sun visors but I think they are similar to what was in my 201 that I just replaced with Rosen Sun Visors. They are well worth the money and not expensive....I highly recommend them. Quote
lithium366 Posted March 2, 2021 Report Posted March 2, 2021 On 3/1/2021 at 10:07 PM, bcwiseguy said: Attached is a small picture showing the sun visors that were installed when I had the airplane. It's not a great pic but it's the only one I have left after a hdd crash. I don't really remember much about the sun visors but I think they are similar to what was in my 201 that I just replaced with Rosen Sun Visors. They are well worth the money and not expensive....I highly recommend them. Expand These Rosen look great but only for 1968+ with top side mount. Thanks for the picture! Quote
carusoam Posted March 2, 2021 Report Posted March 2, 2021 Ilya, There are a few threads around here by people who have built their own... Based on the change that occurred somewhere along the line... some planes got the mounting hardware, and some did not... Best regards, -a- Quote
