  • 2 weeks later...
Did the FAA e- form like instructed, 5 days later got the new registration. Seems to work out ok. As long as we get a notice when its about time to re-register i dont think it will be an issue.
The FAA rule on re-registration is based on the month in which your aircraft was registered.
Some have stated this is the date on your current registration, others have said it is based on the original registration from the factory.
Those receiving re-registration now should have aircraft registered in March of any year.
Anyone that has recieved the notice for re-registration. Can you confirm the date for your plane. Is it your current registration date or the one on your airworthiness certificate?
  • 9 years later...
