I bought a McFarlane vernier mixture cable to put in my 66 C with manual gear. At first glance, my mechanic expressed concern about the location of the gear latch interfering with the install. I have seen photos of several manual gear models with the same control—can anyone comment on any issues? I don’t want to drill a bigger hole only to learn the installation is not workable.
Thanks,
Zack
Thanks,
Zack
I just did this on my 65 manual gear 'C. Other than it being a pain in the ass to do anything with those controls, I didn't have any issues with the gear latch specifically.
Oh yeah, I also took the opportunity to swap the mixture and prop to the standard positions. I did an engine overhaul so I replaced all the controls at the same time. Not sure that it matters since the prop control I installed is also a vernier.  I can take some pics if you want. Just let me know.
Edited by salty
Photos would be great thanks. I may do all three cables. I’d be surprised if they aren’t original.
Edited by woodz
They look original to me.
It's really difficult to get pictures, it's very tight around there.
next two are the mixture control
Mixture is top left, prop middle, throttle right
 you can see all 3, mixture on top, throttle on bottom
the mixture above the gear block
shows mixture better. there's "plenty" of room ;)
another view of all 3 from upside down, mixture is the closest, throttle furthest
Edited by salty
The photos are great thanks. It’s good to know it can be done. Is that an EDM 900 you have? I’m putting one in next month at annual and that’s what got me going down the path to the vernier mixture.
Yep. It’s awesome.
Original or ancient... hard to tell...
in 65... the C had a big black phenolic knob for the prop...  Mooney must have bought 100k at some auction...
The same knob showed up in some Ks for cowl flap controls...
+1 on replacing knobs with newer... these things have a tendency to fray and fail... after a few thousand hours...
Engine OH is a good time to have that decision...
These guys are amazing. I would not hesitate using these guys for anything in my airplane. I’ve installed a few in the past in aircraft. Thousands of hours of use with out any issues. They actually have the closest thing to the large vernier cables I’ve seen in Mooney’s. Way closer to anything Mcfairlen or ASC has.
http://www.power-trans.net/
-Matt
