The RAD comes as part of JPI's STC for the EDM900 and 930.  The EDM900 only has a small red light compared to the small display that comes with the 930.  Mine will flash when any reading on the EDM is above or below the normal green range.  The ranges are pre-set by JPI when you order it from JPI.  Every unit they send out is programed for your individual aircraft's ranges via a questionnaire that you complete for the order.
Don
  • 3 months later...
if you have an existing EDM 700 with fuel flow, do you have to re-do the whole installation from scratch or can you use the existing wiring? I am thinking of upgrading to an EDM 900 if I redo the whole panel.
Bob, amazing panel, I wish I could convince my Rocket's co-owner to invest into the panel. I'm looking at either a JPI 830 or 900/930... It looks awesome and so much better than my EDM 700 without Fuel Flow...
Thanks !
