I am going to buy an ipad mini for mounting on the yoke , just  VFR use, what do you recommend ? I need everything , I want a separate GPS,  anybody use a Bad Elf GPS . I heard they are good.. Can I buy everything in one place, Where do you recommend ?  Thanks.
The mount you need will require whether you plan on using a shell with the Mini or not. Before I bought the GDL-39, I was using a XGPS150. The Bad Elf will consume some of the Mini's power, so you should probably get some feedback from those that own one. I will dig up the numbers for you on the yoke and suction mounts. Sent using Tapatalk
I bought a XGPS150, but I never use it. I find the built in GPS of mini to work just fine. I have a Ram Mount yoke holder, but currently I still have my Garmin Aera 550 on yoke mount and I use the mini as a hand held. I am thinking about retiring the Garmin and just use the mini as a yoke ,
mount.
Ok, updated:
This is a Ram EZ-ROLL'R mount for a full size iPad. It is designed to use the iPad without any protective cover on it. Part number for one that fits the new iPad Mini is RAM-HOL-AP14U: post-9886-13913510143993_thumb.jpg
This is a complete suction mount setup for the iPad Mini with the mount I showed above: http://www.gpscity.com/ram-mount-apple-ipad-mini-suction-mount-ram-b-166-ap14u.html
This is a complete yoke mount setup for the iPad Mini using the mount I showed above: http://www.gpscity.com/ram-mount-apple-ipad-mini-clamp-mount-ram-b-121-ap14u.html
This is a Ram mount for a Mini with Retina that will accommodate an iPad Mini with or without a protective shell: post-9886-13913511659321_thumb.jpg
This is the part number by itself: http://www.gpscity.com/ram-mount-apple-ipad-mini-tab-tite-tablet-cradle-ram-hol-tab12u.html
This is the part number for a complete suction mount using this Ram mount: http://www.gpscity.com/ram-mount-tab-tite-12-ipad-mini-suction-cup-mount-ram-b-166-tab12u.html
If I remember correctly, they didn't sell the complete yoke mount version of this and you needed to buy the cradle separately.
This is a Ram yoke mount close up: post-9886-13913513257523_thumb.jpg
Depending how you want to go, there are a number of different configurations that you can use. In my plane, I have an iPad Mini yoke mounted using the EZ-ROLL'R mounting plate and I have my iPad Air mounted in a suction mount on the passenger side.
The nice thing about the Ram setup is the interchangeability of the components. I have bought add-ons over the past year because I either added or removed covers for the iPads or I wanted to mount things in a different place.
Thanks for the info , my job is easier with all the help. Anybody else just use the  I pad, built in GPS ?
I use mine in conjunction with a Stratus 2.  However, I will vouch for the effectiveness and reliability of the built in GPS of the iPad mini.  It even works through heated windshields with no problem to an accuracy of 5m.  Pretty darn good.
I do when I forget to turn on the GDL :) Works fine.
Sent using Tapatalk
I use both the pin dock elf and the bad elf pro. They both work really well for signal,, but I would recommend the pro version, even though it costs a little more. The cheaper model that plugs into the iPad will get knocked loose really easily and you loose signal. Mine also stopped working after a few months and I got a replacement from the company at no cost. Go with the pro version. It works off its own batteries, can plug into cig lighter and is stand alone or worn around neck on a lanyard. It connects via Bluetooth to iPad, very quickly.
Hanger neighbor had a really slick spring loaded (scissor mount?) if you will. Primary mount was a ram mount but the contraption that held the mini allowed access to what ever you needed on the mini. It was nice, light , and efficient looking. 4 little rubber prongs that grabbed the IPad.
I'll try and see what it was!
-Matt
-Matt
Sounds like the Ram X-Grip http://www.rammount.com/Products/XGriptradeMounts/tabid/4687/Default.aspx
Check out the Delorme inReach for an external gps source that also provides 2 way messaging anywhere, tracking and SOS/SAR alerting for an additional subscription fee. Works great and I'd highly recommend it as a companion to the iPad mini.
