So, I went into my CSC DUATS account to make sure everythign was up to date and found a section on Performance Based Navigation Types. Does anyone know where one could find a summary of what these mean?
PBN/ Check up to 8 Performance Based Navigation Types A1 - RNAV 10 (RNP10)
B1 - RNAV 5 All Permitted Sensors
B2 - RNAV 5 GNSS
B3 - RNAV 5 DME/DME
B4 - RNAV 5 VOR/DME
B5 - RNAV 5 INS/IRS
B6 - RNAV 5 LORAN C C1 - RNAV 2 All Permitted Sensors
C2 - RNAV 2 GNSS
C3 - RNAV 2 DME/DME
C4 - RNAV 2 DME/DME/IRU
D1 - RNAV 1 All Permitted Sensors
D2 - RNAV 1 GNSS
D3 - RNAV 1 DME/DME
D4 - RNAV 1 DME/DME/IRU L1 - RNP 4
O1 - Basic RNP 1 All Permitted Sensors
O2 - Basic RNP 1 GNSS
O3 - Basic RNP 1 DME/DME
O4 - Basic RNP 1 DME/DME/IRU
S1 - RNP APCH
S2 - RNP APCH with Baro
T1 - RNP APCH with RF (Auth Required)
T2 - RNP APCH without RF (Auth Required)
Also found a section on ADS-B. In there, found something that indicates there is such thing as ADS-C. What the heck is that?
-No ADS-B Capabilites-
B1 - ADS-B Capable - 1090 Out
B2 - ADS-B Capable - 1090 In/Out -No UAT Capabilities-
U1 - UAT Capable - UAT Out
U2 - UAT Capable - UAT In/Out -No VDL Capabilites-
V1 - VDL Capable - VDL In
V2 - VDL Capable - VDL In/Out -No ADS-C Capabilites-
D1 - ADS-C Capable - FANS/1
G1 - ADS-C Capable - ATN
Both ADS-C S - Standard Equipment*
N - None
A - GBAS Landing System
B - LPV (APV w/SBAS)
C - LORAN C
D - DME
F - ADF
G - GNSS/GPS
GNSS Augmentation: -None-GBASSBAS H - HF RTF
J1 - CPDLC ATN VDL Mode2
J2 - CPDLC ATN FANS 1/A HFDL
J3 - CPDLC ATN FANS 1/A VDL Mode A
J4 - CPDLC FANS 1/A VDL Mode2
J5 - CPDLC 1/A SATCOM INMARSAT
J6 - CPDLC 1/A SATCOM MTSAT
J7 - CPDLC 1/A SATCOM Iridium
I - Inertial Navigation K - MLS
L - ILS
M1 - SATCOM
M2 - MTSAT
M3 - IRIDIUM
O - VOR
R - PBN Approved
T - TACAN E1 - FMC WPR ACAR
E2 - D-FIS ACARS
E3 - PDC ACARS
U - UHF RTF
V - VHF RTF
W - RVSM
X - MNPS
Y - VHF w/ 8.33khz Spacing
Z - Other - Use Remarks Section and NAV/
The AIM is the place to look for the definition of all these codes. I don't know the exact section but it's in there somewhere.
You might try FltPlan.com.  It is a very useful free resource.  Once you sign up, you can build a profile of your plane (See the menu on the left side of the home page.)  It will walk you through all of the choices and provide the proper codes for your airplane if you choose to use the ICAO flight plan form, which is said to help your chances of getting GPS direct IFR routing.  If you use this service to file your flight plan, they will also email or txt you the route that you are likely to be given by ATC.
Thanks guys! There were a lot of codes in there that I had never seen before. I thought my business had overdone acronyms, but this list puts it all to shame!
