aerobat95 Posted August 4, 2012 Report Posted August 4, 2012 Hey guys quick question for you.....does the Garmin 430 have to have the GI-106A CDI? Or can it use others? Quote
Awful_Charlie Posted August 4, 2012 Report Posted August 4, 2012 It can use others - eg an Aspen (and probably more too!) Quote
Lionudakis Posted August 4, 2012 Report Posted August 4, 2012 It has outputs compatible to most any CDI, the GI-106A has the annunciation built in to meet certain requirements in the install manual (distance from center, source etc. come to mind) Quote
Cruiser Posted August 4, 2012 Report Posted August 4, 2012 check the specs for signal voltage. Some older CDIs may not be supported Quote
aerobat95 Posted August 4, 2012 Author Report Posted August 4, 2012 If I were to have the KI 209A would I need to get an annunciator panel? My current set up is with a Apollo GX-50 and I have a annunciator panel that has two buttons....one for Nav/GPS and the other for GPS SEQ. Quote
N601RX Posted August 4, 2012 Report Posted August 4, 2012 It has to be a non converter type. (up, down,left,right inputs)KI 206 and kni 520 are cheaper options if that is what you are looking for. There are also some older Collens units that will work. Quote
aerobat95 Posted August 4, 2012 Author Report Posted August 4, 2012 Yea I am trying to keep costs down and the GI-106A is pretty $$$. I am not sure what KI I have currently installed but it is hooked up to my Nav/Com radio Quote
N33GG Posted August 4, 2012 Report Posted August 4, 2012 I may be wrong here, bit I don't think the King 209 will work with the 430. Quote
M016576 Posted August 4, 2012 Report Posted August 4, 2012 Quote: aerobat95 Yea I am trying to keep costs down and the GI-106A is pretty $$$. I am not sure what KI I have currently installed but it is hooked up to my Nav/Com radio Quote
N601RX Posted August 4, 2012 Report Posted August 4, 2012 The one you have for gx 50 should be a non converter type. Check the 337 that was filed for the gx 50 and it should tell you which one you have Quote
N601RX Posted August 4, 2012 Report Posted August 4, 2012 The 209 will not work since it has the internal converter. The 209a will since it has internal relays to bypass the converter Quote
aerobat95 Posted August 4, 2012 Author Report Posted August 4, 2012 So this one will work?? http://www.aircraftspruce.com/catalog/avpages/kingKX155_indicator3.php Quote
N601RX Posted August 4, 2012 Report Posted August 4, 2012 I'm pretty sure the one you have for the gx 50 will work if it includes a glideslope on the nav side Check the model of it. Quote
aerobat95 Posted August 4, 2012 Author Report Posted August 4, 2012 The one I have with the GX 50 just shows course....no glideslope. Quote
N601RX Posted August 4, 2012 Report Posted August 4, 2012 The cheapest install is going to depend if you want to share the 430 indicator with a nav radio like the kx155. If you want to share it with a nav radio like the kx155 then the 209a or 106a may be the cheapest route. otherwise you will have to install one of the ak 950 or md 41 relay banks plus a composite to analog output converter(kn 72 if i remember correctly). If you dont want to share it then you have some cheaper options like the ki 206 or kni 520. Quote
OR75 Posted August 5, 2012 Report Posted August 5, 2012 you can download the GNS 430 install manual from several websites. (google search). you can see in the instal diagrams all the indicators that can be. used. Quote
stevesm20b Posted August 5, 2012 Report Posted August 5, 2012 The indicator from a collins 351 nav radio will work and is a lot cheeper than the garmin ind. Also the Mid-Continent MD200-306 CDI works very well with the 430/530,gtn650/750 and SL-30. Quote
aerobat95 Posted August 14, 2012 Author Report Posted August 14, 2012 For my install I would have a dedicated CDI for the Garmin 430, but to save panel space I do not want an annunciator box. The 430 would be place in the center radio stack as well so the distance issues should not be a problem. Quote
N601RX Posted August 14, 2012 Report Posted August 14, 2012 If your wanting the cheapest CDI that will work it will be the KNI 520 probably. It has retangular movement, the only downside is that the the obs knob is in the lower right instead of lower left. Southeast did have have some overhauled ones on sale for $500 a few months ago or on ebay for under $200. Be careful with some of the older stuff with low serial numbers, some of it requires expensive upgrades before it can be repaired. Quote
aerobat95 Posted August 14, 2012 Author Report Posted August 14, 2012 Right now I am looking at the 209A....aircraft spruce has them on sale for 1395.00 and thats for a new one. So thats not bad....and about 700 less than the Garmin 106....so what would I be losing if I went with this....for almost 700 there must be something I am not getting? Quote
danb35 Posted August 14, 2012 Report Posted August 14, 2012 Does the 209A have the GPS/VOR annunciator built into it? You may not need it in your installation, but the 106 has this. Might explain part of the cost difference, anyway. Quote
aerobat95 Posted August 14, 2012 Author Report Posted August 14, 2012 I dont think it does have the annunciator built in....I don't think I will need it though as the 430 has sufficient annunciations built into it. From what I am reading if it were installed on the co-pilots side or if the throttles were in the way then the annunciator would be required. $700 for a little light in the CDI to tell me what I already know seems excessive.... Quote
aerobat95 Posted August 15, 2012 Author Report Posted August 15, 2012 Quote: JimR I've got a 209A installed in my Mooney and I also had one installed in my previous Cherokee 180. No complaints. No annunciator. They both have worked well and have never required maintenance. Your results, of course, could vary. Jim Quote
