Fix Posted December 8, 2025 Report Posted December 8, 2025 I was about to make a post some weeks ago about this topic, saw in that there was a Post in another section. But would like to talk more specific about M20K. Is there a "official" Winterization Kit? I found something about it on some Mooney document, but could find anything when I Google the part #. Here at Northern Europe we get semi cold weather from October to March. I use AeroShell 100W Plus + Camguard and this authumn I didn't change to Aeroshell 80W Plus and I started to get some "issues" with fluctuating MP when OAT were about 10 Celsius. When below >10 Celsius I pre-heat my engine, but it didn't help with the fluctuating MP. So I started to cover my oil cooler about 40% with Aluminum foil tape. When I did a flight at FL100 with OAT around 7-9 Celsius engine temp was fine and MP stable. But when OAT was around 5-6 on ground it started to fluctuate again. Will change oil next week to Philips X/C 20W50 + Camguard so I can use same oil whole year without changing from 100W to 80W and vice versa. Questions: How much of the oil cooler is OK to cover? - I've found somewhere that some covered whole oil cooler, too much? (depending on OAT) Is there a good way to check the Oil Temp Probe (Stock) - Measure Ohm and heat it? And what Ohm/Temp on the probe to check the Oil Temp gauge (Stock) so it's correct.
PeteMc Posted December 9, 2025 Report Posted December 9, 2025 4 hours ago, Fix said: I use AeroShell 100W Plus + Camguard and this authumn I didn't change to Aeroshell 80W Plus and I started to get some "issues" with fluctuating MP when OAT were about 10 Celsius. What about using Phillips 66 X/C 20W-50 for the winter? And if I get a chance, I'll take a picture of my winterization plate. No clue if it's "official" or not, it came with the plane.
Ragsf15e Posted December 9, 2025 Report Posted December 9, 2025 17 minutes ago, PeteMc said: What about using Phillips 66 X/C 20W-50 for the winter? And if I get a chance, I'll take a picture of my winterization plate. No clue if it's "official" or not, it came with the plane. @Fix there is an actual approved winterization plate! I believe it’s a small piece of sheet metal that you can flip up or down depending on conditions, but @PeteMcs picture will tell us for sure. I tried to order one through lasar a while back and basically they didn’t have any and then ghosted me on it. I plan to use tape this year. Interestingly, i flew in very cold air last year and didn’t notice the issues with mp you mentioned. My issue was that my oil wouldn’t stay above about 120 deg f in cruise which isn’t warm enough. This was around -20c at cruise altitude. Im glad pete has an example of the plate he can show us! ** I use xc20w-50 and CG year round, so maybe that’s why I didn’t have the mp issues?
Fix Posted December 9, 2025 Author Report Posted December 9, 2025 18 hours ago, PeteMc said: What about using Phillips 66 X/C 20W-50 for the winter? Then I can use AeroShell 80W Plus if I want to use "two" different oils. Will use Philips X/C 20W50 + Camguard all the time in future.
Fix Posted December 9, 2025 Author Report Posted December 9, 2025 18 hours ago, Ragsf15e said: Interestingly, i flew in very cold air last year and didn’t notice the issues with mp you mentioned. My issue was that my oil wouldn’t stay above about 120 deg f in cruise which isn’t warm enough. This was around -20c at cruise altitude. Im glad pete has an example of the plate he can show us! ** I use xc20w-50 and CG year round, so maybe that’s why I didn’t have the mp issues? I also have some problems to get the Oil temp up when it's cold or less than 10c. Suspect that AeroShell 100W is little bit to cold to flow properly then, giving me MP fluctuations. Philips X/C 20W50 would most probably work much better, and I will change next week or at next annual and use it both summer/winter. Have 7x AeroShell 80W on the shelf that I might use this time, since I won't fly many hours until my Annual i February due to bad weather here.
PeteMc Posted December 10, 2025 Report Posted December 10, 2025 (edited) 8 hours ago, Fix said: Suspect that AeroShell 100W is little bit to cold to flow properly then, giving me MP fluctuations. Once the engine has warmed up, I doubt the 100w has anything to do with the MP fluctuation. My concern with that weight of oil would only be at the startup. Great in the summer, sludge in the winter. And as for my plate, which screws in, I didn't get a chance to look for it yet. Quite honestly, when I lived back east I never really needed to install it. And although it got pretty cold even in the summer in the teens, the oil temp never got out of the green. I guess in the winter there is that potential, but I really haven't done any long X-US flights in the winter due to the icing potential. So it's always been shorter flights. Edited December 10, 2025 by PeteMc 1
Jackk Posted December 10, 2025 Report Posted December 10, 2025 (edited) +5C is like 42F, that’s not even “cold” Per Continental SIL 03-1 cold weather ops start at like 20F For me I wouldn’t change anything if it’s only 42F outside As always I’d just warm the jugs to 200F or so before I put much power to the plane Some folks do more damage than good trying to keep a engine warm that isn’t even cold, another best intentioned bad idea is the guys who leave the engine oil heater on 24/7 in winter I think your MP fluctuations are a different issue Continental SIL 03-1 Cold Wx Ops.pdf Edited December 10, 2025 by Jackk
Falcon Man Posted December 11, 2025 Report Posted December 11, 2025 My IA and I made two plates to cover the oil cooler - one is ~ 1/3 and the other is ~ 1/2 of the surface. I believe the Mooney Weatherization Oil Cooler cover "Kit" is long gone MIA.
Fix Posted January 12 Author Report Posted January 12 (edited) Found a picture of the official Winter Kit Plate. You can find it in Mooney M20K IPC under 71-00-03 Edited January 12 by Fix
Ragsf15e Posted January 19 Report Posted January 19 On 1/12/2026 at 1:33 PM, Fix said: Found a picture of the official Winter Kit Plate. You can find it in Mooney M20K IPC under 71-00-03 That covers a lot! I covered a third of my cooler with metal tape and it made a noticeable improvement in oil temp. 1
Ragsf15e Posted January 20 Report Posted January 20 I should have taken a picture... however, I covered approximately a third of my oil cooler with hvac metal tape. I then flew in medium cold weather. ~0c at takeoff. (inversion) ~-8 c at 15,500' cruise. Oil temp held about 145f which for me is warmish. I then removed about 1/2 of the tape so only a small part was covered and I was back around 130f. Yes, yes, I know, it should be 180f. However, the probe is right after the cooler, so I'm not so sure that's the hottest point of the oil. I'm going to try covering just a little more and see if I can bring it up another 10 degrees. The tape was pretty easy to remove too, so that's good. 1
Ragsf15e Posted January 30 Report Posted January 30 So today I tried covering about 2/3 of the oil cooler. Hvac metal tape has worked well and comes off easily enough. I honestly think my oil temp reads lower than actual oil temp just because it measures right after the cooler because I normally see ~130f in cold temps but lots of steam coming off after flight when I open the oil cap. Anyway, today with 2/3 covered, I got 175 in the climb and 145 in cruise so it definitely makes a difference, but 175f in the climb yields ~38psi oil pressure which is in the lower end of the green. So I think if I was to cover up enough of the cooler to get oil temp up to 180 (in the climb), Im going to be right on the bottom of acceptable pressure. Since oil analysis always seems fine, i think Im going to compromise and cover just enough to keep oil temp indicating 135-145 as it does in the summer and believe that somewhere in the oil system it’s hot enough to burn off the water.
Aerodon Posted January 30 Report Posted January 30 The Arrow / Seneca also has a TSIO 360. Piper has a plate that blocks off 1/3rd of the oil cooler. We fabricated and identical plate to block off another 1/3rd. So I am not surprised that you are fining the same in a 231. Aerodon 1
Jetrn Posted February 1 Report Posted February 1 (edited) Here is a picture of the winterization kit on my plane I have never had to use it being in Northern California. It can be made referencing the IPC does not need to be purchased from Mooney. Edited February 1 by Jetrn 1
Fly Boomer Posted February 1 Report Posted February 1 10 hours ago, Jetrn said: Here is a picture of the winterization kit on my plane I have never had to use it being in Northern California. Looks like piano hinge and a piece of sheet metal with a matching latch (same color) that holds it away from the cooler. What holds it against the cooler in the other position?
Jetrn Posted February 1 Report Posted February 1 @Fly Boomer Easily made with piano hinge, countersunk rivets, and Sheet metal. Air flow holds it down. 1 1
