Does anyone know where I can buy the connectors for this? I was able to find one under Bendix PN 030-1094-60 (36 pin) but I cant find the 030-1094-59 (30 pin) and no one sells install kits for these. Im sure its a common universal part, but dont know where to look. I just need the connectors, I already have the pins. Thank you guys!
Edited by robert7467
I checked what I have left and I'm afraid I don't have what you need.  I sold the KX165 & tray long ago, and might have included the ship-side connector with it.
Make sure you put in the two zeros before the "59" on the part number.  Most Bendix King part numbers from this era go like this: XXX-XXXX-XXXX
The connectors were made by Molex. They were discontinued in about 2015. People went crazy, so they started making the pins again. I don’t think they are currently making the housings. If you need a housing, it will be used or old stock.
The situation may have changed, so check it out for yourself.
I think my avionics guy who is now deceased ordered them from mouser or digikey or something like that. It's when I try to pull it up by Bendix's part number nothing is pulling up since thar part number is so old.
Pins are also available on eBay.  But be careful, there are different sizes (height of pin), I guess for slightly different bach shells or board thickness?  Spend the extra $$ and buy from the guys you have them still packed in the BK packets.
Aerodon
I got the correct pins :)
