christaylor302 Posted April 17, 2025 Report Posted April 17, 2025 I’m restoring a ‘66 M20C with an Accu-Trak B11 installed. However the vacuum system is a mess and I don’t know if any of the Accu-Trak components work. It looks like some of the vacuum lines were cut away. I’m trying to decide if I should attempt to restore the Accu-Trak system, or remove it and the vacuum system. Maybe I try putting together a STEC system in the future? I plan on mostly VFR and some light IFR when required. I know there will be opinions on both sides, but I’m interested in hearing any suggestions or experience. How does a M20C handle without the Accu-Trak or PC system? I’m trying to keep the first wave of expenses within reason (LOL). This will not be an all Garmin glass plane. Thanks,Chris
Greg Ellis Posted April 17, 2025 Report Posted April 17, 2025 4 hours ago, christaylor302 said: How does a M20C handle without the Accu-Trak or PC system? I have a 63 C model. It came without any PC system, wing leveler, or anything. I have owned this airplane for 17 or 18 years now. For about 14 years I hand flew (no autopilot) IFR sometimes to minimums. The airplane is very stable without an autopilot if well rigged and trimmed well. I now have a Garmin GFC 500 and love it but the plane did very well without any autopilot.
KSMooniac Posted April 17, 2025 Report Posted April 17, 2025 You won't be able to legally install a used STEC and I don't believe any of the available models new are certified for a C. The old TruTrak now Aerocruz might be an option and a frugal choice. I have no experience but have read many times that the Brittain/PC system is simple and reliable when the components are working and there are no leaks. Troubleshooting the vacuum lines is straightforward. There is no support that I'm aware of to rebuild or overhaul components, but I have seen steady availability of take-out parts since owners are upgrading. A working PC system, especially with a working Brittain autopilot, would be way better than nothing IMO. If you're able to scrounge parts and install/troubleshoot yourself versus paying for that labor, it might be a good option. Or you could get dozens of hours into it and find you're missing something, or can't get a component fixed. The Aerocruz can be installed by an A&P/IA and potentially by an owner with supervision if so inclined. All of the parts will be in a box with instructions and support. It will work, and it will make the plane easier to sell in the future too. If the plan is not to fly long trips anywhere, then I would skip all of the options, but Mooneys are meant to travel and IMO should have at least a basic AP for those long days. Sent from my motorola edge plus 2023 using Tapatalk
BrianWilkins Posted April 17, 2025 Report Posted April 17, 2025 “Light IFR” without an AP is fine in my opinion and I did quite a bit of that in my E before I got a new panel. I don’t think you’d want to do hours and hours of IMC without one though. Trying to get the old Britain system working is probably going to be next to impossible based on my attempts. Only real option right now is Garmin because Dynon and others just aren’t interested in certifying for the older models. The Garmin is incredible but very, very expensive.
LANCECASPER Posted April 17, 2025 Report Posted April 17, 2025 1 hour ago, BrianWilkins said: “Light IFR” without an AP is fine in my opinion and I did quite a bit of that in my E before I got a new panel. I don’t think you’d want to do hours and hours of IMC without one though. Trying to get the old Britain system working is probably going to be next to impossible based on my attempts. Only real option right now is Garmin because Dynon and others just aren’t interested in certifying for the older models. The Garmin is incredible but very, very expensive. @cliffy installed an Aerocruze 100, so there is another option.
cliffy Posted April 17, 2025 Report Posted April 17, 2025 I have posted here on MS my experience with the AeroCruze 100 (TT) autopilot. I installed it as an A&P No "approved" shop required for the install. It works fine in my D model for a basic VFR A/P and light IFR. It will do GPSS if wanted. Install is not difficult. Has "one button push" for straight and level flight great for inadvertent IMC. I removed a working Accutrak for the A/C 100. Much happier with the A/C 100. Can;t beat the price (in a Mooney) for a working A/P The choices are very limited. If you want a good A/P for a VFR Mooney ( or light IFR) go Aerocruze 100 If you do heavy IFR to mins all the time spend the money on Garmin $$$$$$$ LANCECASPER was writing as I was typing :-) 4
Utah20Gflyer Posted April 17, 2025 Report Posted April 17, 2025 Unless you can do all of the work yourself and don’t mind spending the time to do it the Brittian system is not going to be cheap to fix. It would be more cost effective I think to install the Aerocruze auto pilot. I worked on my PC system some when I first bought my plane but kept having problems and eventually ripped out everything including the vacuum system. The PC systems in our planes are 50+ years old, if you want it to work properly it’s probably going to require replacing and rebuilding everything in the system. Not worth it in my opinion. If I had a system that worked I’d run it until it stopped working but not worth the investment in time and money to rebuild it. A Mooney flys great without an autopilot. I’d say as good or better than any other light airplane. That being said I’d still like one and plan on getting one in the next couple of years.
Vance Harral Posted April 17, 2025 Report Posted April 17, 2025 We have a fully working Brittain PC/B-5 system, and it's nice for what it is (75-year-old technology). But at this point, I think the question of resurrecting a non-working Brittain system has less to do with cost and workload - which are manageable - and more to do with the availability of mundane parts: vacuum lines, servo boots, etc. http://www.brittainautopilots.com/ is still online with a listed phone number, but it's my understanding that people who have recently tried to obtain parts either never get a response, or get a response that the company is "in limbo" with little or no legal ability to actually make parts. That leaves salvage items, kludge fixes, and under-the-table deals, which is a frustrating scenario for an aircraft owner. It is not difficult to debug why the system isn't working, but once you identify the problem(s), you may find it difficult to resolve them in a satisfactory manner. In our case, we have a small cache of spares, but maintaining the system has begun to feel more like maintaining a warbird than a certified airplane.
DCarlton Posted April 17, 2025 Report Posted April 17, 2025 Like many have mentioned in other PC related posts on Mooneyspace, Kevin Westbrook is the remaining most knowledgable person regarding the Brittain Autopilots. He's a member here. If you decide to troubleshoot or restore, he should be able to help even if over the phone. He's helped me keep mine operational. As a mechanical engineer by degree, and someone who loathes software updates, it's a design I still admire. There are schematics available if you wanted to start with basic troubleshooting and check your vacuum lines and servo boots for leaks. https://mooneyspace.com/profile/48565-kevin-westbrook/ 2
Kevin Westbrook Posted April 17, 2025 Report Posted April 17, 2025 Chris Kevin Westbrook here I worked at Brittain call me 539-292-0474 and we can talk about the system!!!! 6
Echo Posted April 17, 2025 Report Posted April 17, 2025 Servos are still available on Ebay. The controller is also available on Ebay. I just say a B5 listed for very reasonable money. It's just plastic tubing and rubber tubing you can get off of Amazon. I am very pleased with my Accu-Flite install. It was like 1500 parts and labor to get a heading bug auto pilot in my plane. I did thee B5 and plumbing myself. Pretty straight forward stuff. My servos look great at 60. Better than me for sure. 3
takair Posted April 18, 2025 Report Posted April 18, 2025 Kevin is THE man. Almost all parts can be restored or found. Most pop up on eBay. Only Pegasus is the altitude hold servos if you have that system but I’m convinced there is an answer for that. I have a bunch of spare parts I’ve accumulated, just haven’t had time to organize and post them….if Kevin can’t fix it he knows where to find me. As others have indicated the biggest investment is your time and a willing AP who will allow owner assist or hangar else with the right attitude. 1
christaylor302 Posted April 18, 2025 Author Report Posted April 18, 2025 I appreciate everyone's responses. This is all great information. I did have a great call with Kevin yesterday. So much knowledge and just a really nice person. Thank you taking my call Kevin! I've decided I'll take a wack at restoring the system. I do need the trim valve in the yoke, it's missing, and at least one aileron servo/boot. I still need to test the rest of the system to see if the other boots are ok. But if it becomes a PIA, I won't worry about just removing the system and going without. Maybe an Aerocruze 100 is in the future . Thank you everyone! 3
jeremyc209 Posted August 26, 2025 Report Posted August 26, 2025 On 4/18/2025 at 2:04 PM, christaylor302 said: I appreciate everyone's responses. This is all great information. I did have a great call with Kevin yesterday. So much knowledge and just a really nice person. Thank you taking my call Kevin! I've decided I'll take a wack at restoring the system. I do need the trim valve in the yoke, it's missing, and at least one aileron servo/boot. I still need to test the rest of the system to see if the other boots are ok. But if it becomes a PIA, I won't worry about just removing the system and going without. Maybe an Aerocruze 100 is in the future . Thank you everyone! Did you get your PC system running? I have the same PC/B11 setup and it was a mess but I got it working great just recently and it's definitely worth it. The Accutrak seems to work but VOR navigation isn't particularly useful, I'm having it connected to the CDI/GPS that's going in soon. The PC allows for very straight flight once trimmed out and it's nice in light turbulence. I installed two aileron servos (previous owner removed them at some point and got rid of them, but it's not a bad job to put them in), and replaced a bunch of the vac lines, there were some unnecessary T's etc from someone fiddling with it before and the gyro wasn't connected to the vacuum source properly. Following the maintenance manual carefully gives you all the info you need. I'm not a fan of the disconnect button on the yoke though, the controls are way too stiff to leave it on in the pattern and annoying to hold the button while trying to make radio calls. Hopefully I can figure out a good panel mounted switch like I've seen Brittain put in some planes. If anyone has a part number or advice there I'm all ears.
McMooney Posted August 26, 2025 Report Posted August 26, 2025 If you can, why not, it's not costly at all. after fixing(taping) mine, i can't see why the pneumatic/vacuum servos aren't used everywhere, no way they aren't more reliable than the electrical servos. My next upgrade is most likely the trutrac
christaylor302 Posted August 26, 2025 Author Report Posted August 26, 2025 Did you get your PC system running? I have the same PC/B11 setup and it was a mess but I got it working great just recently and it's definitely worth it. The Accutrak seems to work but VOR navigation isn't particularly useful, I'm having it connected to the CDI/GPS that's going in soon. The PC allows for very straight flight once trimmed out and it's nice in light turbulence. I installed two aileron servos (previous owner removed them at some point and got rid of them, but it's not a bad job to put them in), and replaced a bunch of the vac lines, there were some unnecessary T's etc from someone fiddling with it before and the gyro wasn't connected to the vacuum source properly. Following the maintenance manual carefully gives you all the info you need. I'm not a fan of the disconnect button on the yoke though, the controls are way too stiff to leave it on in the pattern and annoying to hold the button while trying to make radio calls. Hopefully I can figure out a good panel mounted switch like I've seen Brittain put in some planes. If anyone has a part number or advice there I'm all ears.I really wanted to restore the original system but after a partial repair I decided to remove it. There were still many unknowns to be discovered in the PC, Accutrak and the rest of this project. I also found my AI and DG needed to be replaced.So I decided to remove the vacuum system and install a pair of AV30Cs.An AeroCruze 100 will probably be installed in a couple years after the wallet recovers from this resurrection project. 1
jeremyc209 Posted August 26, 2025 Report Posted August 26, 2025 Makes sense. The AV30s are nice little units, the 172 I trained in a bit had a pair.
Echo Posted August 27, 2025 Report Posted August 27, 2025 (edited) On 4/17/2025 at 11:15 AM, Utah20Gflyer said: Unless you can do all of the work yourself and don’t mind spending the time to do it the Brittian system is not going to be cheap to fix. It would be more cost effective I think to install the Aerocruze auto pilot. I worked on my PC system some when I first bought my plane but kept having problems and eventually ripped out everything including the vacuum system. The PC systems in our planes are 50+ years old, if you want it to work properly it’s probably going to require replacing and rebuilding everything in the system. Not worth it in my opinion. If I had a system that worked I’d run it until it stopped working but not worth the investment in time and money to rebuild it. A Mooney flys great without an autopilot. I’d say as good or better than any other light airplane. That being said I’d still like one and plan on getting one in the next couple of years. Did the servos in wing and tailcone get removed? Servos are on ebay and not that expensive. I did majority of installation of an AccuFlite with Avionics tech doing install of on/off switch in panel. If the tubing has been removed on sidewall that would be a pain, but if it is just replacing torn rubber on servos and reconnecting it is not that complicated and definitely not that expensive...Unless adding unnecessary altitude hold. With heading bug set and plane trimmed mine holds course and flies hands free. Nevermind...I see now you punted. No CB Club for you Edited August 27, 2025 by Echo 1
christaylor302 Posted August 27, 2025 Author Report Posted August 27, 2025 Did the servos in wing and tailcone get removed? Servos are on ebay and not that expensive. I did majority of installation of an AccuFlite with Avionics tech doing install of on/off switch in panel. If the tubing has been removed on sidewall that would be a pain, but if it is just replacing torn rubber on servos and reconnecting it is not that complicated and definitely not that expensive...Unless adding unnecessary altitude hold. With heading bug set and plane trimmed mine holds course and flies hands free. Nevermind...I see now you punted. No CB Club for you I am a DIY CB, but when the wife says your time is worth more than that and buys you shinny new things… 1
