McMaster Carr sells them, I just don't remember the thread size. Someone will be along. Be sure to get one with a flange at the bottom. 5/8-11 rings a bell, but it's been well over a decade since I had all three rings powder coated.
3 hours ago, Utah20Gflyer said:
Lasar makes an upgraded one, I’ve considered buying it but never got around to it.
I've seen their wing tie down, what's different about the tail one?
2 hours ago, Skates97 said:
Just flat stainless steel.
Likely, the mount bolt spacing is the same, but the pic below is the ‘63C tail tie down/skid plate version.
The eyebolt isn’t listed in moodychief’s ‘61-‘64 model’s IPC (as far as I could tell).  The ‘65-‘68 IPC lists the eyebolt as pn 350122-001, the ‘68-‘76 IPC (Manual 205)  as pn 350122-003.
Salvage yards are your best bet, if you want a legit Mooney part.  Eyebolts from the hardware store can probably be made to work, at your (and your A&P/IA’s) discretion.
No idea of part numbers, but that's what it looks like on my 1970 C.
No reason a good eye bolt from most anywhere won't work, as long as it screws in. Just get an eye bolt with a shoulder, so it will screw in securely against the flat piece on the bottom.
