WheelPantsOff Posted December 26, 2024 Report Posted December 26, 2024 Good evening, I hope everyone had a safe and joyous Christmas and is thoroughly enjoying the holiday season. I think I have a vacuum leak and am wondering where I start troubleshooting or having the shop investigate. First, the SBS on the left side retracts significantly slower than the right side. Second, when pressing the extend/retract button, the pitch of the sidetone changes significantly through the headsets. I only have the idiot light on the panel so I can't say what the vacuum is actually pulling. The pump is about 5 years old and ~350 hours. Thanks in advance!
M20F Posted December 26, 2024 Report Posted December 26, 2024 Your speed brake (vacuum) on the left retracts slower than the right? What does your idiot light say? Do you have any vacuum instruments? If so how do they work?
WheelPantsOff Posted December 26, 2024 Author Report Posted December 26, 2024 1 hour ago, M20F said: Your speed brake (vacuum) on the left retracts slower than the right? What does your idiot light say? Do you have any vacuum instruments? If so how do they work? Correct. SBS light is too dim to be meaningful. Even in the nighttime, it's of marginal utility. Yes, ADI. It seems to work as intended and no obvious issues. The left side retracting slowly happened during the runup and in-flight. I flew it for 6-00 earlier and that's the only squawk I have for it.
M20F Posted December 27, 2024 Report Posted December 27, 2024 32 minutes ago, WheelPantsOff said: Correct. SBS light is too dim to be meaningful. Even in the nighttime, it's of marginal utility. Yes, ADI. It seems to work as intended and no obvious issues. The left side retracting slowly happened during the runup and in-flight. I flew it for 6-00 earlier and that's the only squawk I have for it. I will let smarter people than me comment. If your vacuum AI is working per normal and your right speed brake works fine, I would say not a vacuum issue.
PT20J Posted December 27, 2024 Report Posted December 27, 2024 How much slower is "significantly"? I have electric speed brakes and the left is maybe a second slower than the right (I haven't timed it). It doesn't make any noticeable difference in the way the airplane flies.
IvanP Posted December 27, 2024 Report Posted December 27, 2024 I suggest looking at the cable and the brake box on the affected side. The vacuum speedbrakes are both activated by a single vacuum actuator that pulls on cables connected to the brakes. If the issue would be with the vacuum actuator or pump, it would affect both sides and generally would affect the deployment of the brakes, rarther than retraction. When you disengage the brakes, vacuum is released and springs retract the blades. If your deployment is OK but retraction is slow, it is likely either cable or spring. If the spring is broken, the blades will still retract by gravity, but slower. I had similar issue occur few months ago on 1990 Bravo with vacuum speed brakes. Squirt of TriFlow in the cables fixed it. 1
WheelPantsOff Posted December 27, 2024 Author Report Posted December 27, 2024 11 hours ago, PT20J said: How much slower is "significantly"? I have electric speed brakes and the left is maybe a second slower than the right (I haven't timed it). It doesn't make any noticeable difference in the way the airplane flies. At least 10 or 15 seconds, or at least the time it would take me to process the thought, 'I wonder if this is going to retract by itself or if I'm going to need to rock the wings a little bit' and 'I hope the rental car is at the FBO when I get there because it's a bitch to get these people on the phone.' If I didn't do something, who knows if it would have retracted on it's own. 11 hours ago, IvanP said: I suggest looking at the cable and the brake box on the affected side. The vacuum speedbrakes are both activated by a single vacuum actuator that pulls on cables connected to the brakes. If the issue would be with the vacuum actuator or pump, it would affect both sides and generally would affect the deployment of the brakes, rarther than retraction. When you disengage the brakes, vacuum is released and springs retract the blades. If your deployment is OK but retraction is slow, it is likely either cable or spring. If the spring is broken, the blades will still retract by gravity, but slower. I had similar issue occur few months ago on 1990 Bravo with vacuum speed brakes. Squirt of TriFlow in the cables fixed it. Excellent. I will look at that this weekend. Thank you! 1
LANCECASPER Posted December 27, 2024 Report Posted December 27, 2024 17 hours ago, WheelPantsOff said: First, the SBS on the left side retracts significantly slower than the right side. Second, when pressing the extend/retract button, the pitch of the sidetone changes significantly through the headsets. What year is your J? Are you sure you have vacuum speed brakes and not electric?
RolexRootBeerGMT Posted December 27, 2024 Report Posted December 27, 2024 3 hours ago, LANCECASPER said: What year is your J? Are you sure you have vacuum speed brakes and not electric? Hell, I thought they were all electric.
WheelPantsOff Posted December 27, 2024 Author Report Posted December 27, 2024 7 hours ago, LANCECASPER said: What year is your J? Are you sure you have vacuum speed brakes and not electric? 1981 and these were installed prior to my ownership sometime around the mid 1990s. I'd have to grab the manuals to be certain of the date. 1
