AJ88V Posted January 17 Report Posted January 17 Just want to say thank you to all the contributors of this thread. I'm in the middle of a decision to install/upgrade for my 1970 C model or to just buy another plane. Knowing a lot more detail about the Aerocruz is definitely helping. Thanks!!! 1 Quote
mooneydemi Posted January 29 Report Posted January 29 Thanks from me also. Have a M20E with dynon and avidyne 440 and was waiting for the dynon autopilot but that isn't happening as we know. This sounds promising. Keep the field reports coming. Thanks!!! Quote
cliffy Posted January 29 Report Posted January 29 Did a 3 hr round trip and found tings working well right now BUT I haven't tried to "de-select" to use the Dynon heading bug yet. That will happen on the next trip. After takeoff it grabs heading and climb rate nicely when engaged and climbs to preselected altitude and levels off within 20 feet of selected altitude (CAUTION - you MUST sync the altitude reading of the AC 100 with the reading on your altimeter AFTER you set it to the current altimeter Hg setting. This is spelled out in the manual) . The altitude reading of the AC 100 goes back to 29.92 ref every time it is shut off. Just a quick setting every start and every altimeter change. The trim indication will bother you for a couple hrs until you learn how to check it by tapping the control wheel. Descents are easy as you just set the bottom altitude and then the rate making sure the rate is ZERO before setting the bottom altitude. Levels again within 20 feet every time. Stays within 20 feet during level turns Buttonology will have you thinking for a few hours. Follows flight plan in Dynon perfectly and I had an occasion to need a heading for a while so I transferred from Skyview mode to GPS mode and used the AC 100 control head for the heading control and it works perfectly. Had to reselect altitude hold though. Again buttonology to get used to. At this point with about 5 hrs of time behind it I'm very satisfied. I have a hangar neighbor with a G model who is now going to install one also and get rid of his Brittian. He'll use his G 430 for a AIRINC drive for GPSS steering. As he has a G he has no modifications to do to make it fit with the install kit now supplied, Sure wish it had happened 5 years ago. 4 Quote
hammdo Posted January 29 Report Posted January 29 @cliffy, would you care to share you’re setup settings? Thanks… -Don Quote
mooneydemi Posted January 29 Report Posted January 29 Thanks @cliffy, How many hours do you think the install takes? Wanted to get an idea when I start discussing with my A&P. Appreciate the breakdown above the feedback is great and this sounds like a decent option for us short body guys. Don 1 Quote
cliffy Posted January 29 Report Posted January 29 6 hours ago, hammdo said: @cliffy, would you care to share you’re setup settings? Thanks… -Don They are set in when delivered They are easily found in the installation manual available on line if you need to review them 6 hours ago, mooneydemi said: Thanks @cliffy, How many hours do you think the install takes? Wanted to get an idea when I start discussing with my A&P. Appreciate the breakdown above the feedback is great and this sounds like a decent option for us short body guys. Don Install time will be (or should be ) between 30 to 40 hrs. Maybe a little more if on a short body with mods to make to the pitch mounting. This is my guess for a first time installer. Follow on installs by the same guy will be somewhat shorter but not more than 10-15 hrs shorter. Like I said I'm satisfied by its performance for what I need I can see light IFR capability but not hard IFR down to mins all the time. Also its restricted to basically non-precision mins (700 AGL) Just like the Brittains. But if you can't hand fly the last half of an LPV (when its already set up for you) then you shouldn't be flying in IMC (JMO) Maybe more flying next week when it warms up a little. 2 Quote
Florian Guthardt Posted January 29 Report Posted January 29 18 hours ago, cliffy said: Did a 3 hr round trip and found tings working well right now BUT I haven't tried to "de-select" to use the Dynon heading bug yet. That will happen on the next trip. After takeoff it grabs heading and climb rate nicely when engaged and climbs to preselected altitude and levels off within 20 feet of selected altitude (CAUTION - you MUST sync the altitude reading of the AC 100 with the reading on your altimeter AFTER you set it to the current altimeter Hg setting. This is spelled out in the manual) . The altitude reading of the AC 100 goes back to 29.92 ref every time it is shut off. Just a quick setting every start and every altimeter change. The trim indication will bother you for a couple hrs until you learn how to check it by tapping the control wheel. Descents are easy as you just set the bottom altitude and then the rate making sure the rate is ZERO before setting the bottom altitude. Levels again within 20 feet every time. Stays within 20 feet during level turns Buttonology will have you thinking for a few hours. Follows flight plan in Dynon perfectly and I had an occasion to need a heading for a while so I transferred from Skyview mode to GPS mode and used the AC 100 control head for the heading control and it works perfectly. Had to reselect altitude hold though. Again buttonology to get used to. At this point with about 5 hrs of time behind it I'm very satisfied. I have a hangar neighbor with a G model who is now going to install one also and get rid of his Brittian. He'll use his G 430 for a AIRINC drive for GPSS steering. As he has a G he has no modifications to do to make it fit with the install kit now supplied, Sure wish it had happened 5 years ago. Did they really get the new servo mounts approved yet? on their download section it is still the old 2023 drawings where some mods are required. Not a big deal but most shops are refusing to modify the install... We tried to be as close to the manual on our M20F as possible, still some mods were required (Roll servo rod shortening, roll servo bracket trimming, modifying installation of aft brackets of Pitch Installation, relocating servo on the C-Channel 1/2 inch further forward to ensure proper control travel) Quote
hammdo Posted January 31 Report Posted January 31 @cliffy I do have those numbers— just making sure yours were defaults. Thanks! -Don 1 Quote
Scooter Posted February 4 Report Posted February 4 Hey Guys and Gals, Just got this in for the latest update. Hello Scooter Good news - We have one more meeting to look over the drawings that, the Bendix King and Duncan Engineering, created. These revised additional drawings will be completed this month, then FAA approval after that... We still believe it will be the Q2 of 2025 (is our latest estimate). Scooter 1 Quote
cliffy Posted February 12 Report Posted February 12 On 1/29/2025 at 3:24 PM, cliffy said: They are set in when delivered They are easily found in the installation manual available on line if you need to review them Install time will be (or should be ) between 30 to 40 hrs. Maybe a little more if on a short body with mods to make to the pitch mounting. This is my guess for a first time installer. Follow on installs by the same guy will be somewhat shorter but not more than 10-15 hrs shorter. Like I said I'm satisfied by its performance for what I need I can see light IFR capability but not hard IFR down to mins all the time. Also its restricted to basically non-precision mins (700 AGL) Just like the Brittains. But if you can't hand fly the last half of an LPV (when its already set up for you) then you shouldn't be flying in IMC (JMO) Maybe more flying next week when it warms up a little. Hasn't warmed up yet in fact 30 degrees this morning Brrrrrr! No cracks from the peanut gallery either. I live here to avoid the white crap! Quote
Hank Posted February 12 Report Posted February 12 5 minutes ago, cliffy said: Hasn't warmed up yet in fact 30 degrees this morning Brrrrrr! No cracks from the peanut gallery either. I live here to avoid the white crap! There's a part of Utah where you can avoid snow??? I'm in Alabama, we've had snow three times since I moved back in Feb 2014, but only stuck twice (and then work closed). Quote
cliffy Posted February 13 Report Posted February 13 St George Maybe 2 inches a year and gone by noon :-) Quote
Hank Posted February 13 Report Posted February 13 8 hours ago, cliffy said: St George Maybe 2 inches a year and gone by noon :-) I'm shocked! I thought maybe you just hadn't updated your location. Glancing at the map, that's not too far from Sin City, which also doesn't get much snow. But aren't you in the mountains? Please let us know how the install goes, as this may be in my future too. I'll be digging into my Brittain at annual. Quote
cliffy Posted February 13 Report Posted February 13 We are basically one small ridgeline away from Mesquite, NV so we get a strong desert weather influence from the Las Vegas basin. 2900 MSL and as I write this it just stated the first snow in a year (very light). Quite pleased with the autopilot at this early time. Being a vanguard install some things needed to be figured out but overall for my needs (day, VFR ) it seems a perfect solution. Next week the weather will be better for my flying. 1 Quote
