takair Posted November 15, 2024 Report Posted November 15, 2024 2 hours ago, Ronnie Pool said: If the aileron weights being streamlined is a 0 indication, then my ailerons are rigged slightly up where the book says they should be 0 to 2 deg down…. The flaps are contacting the wing to body fairing so I’m not sure how much more up I can go with them but I’ll give it a shot. My step is fixed unfortunately and is not removable unless I drill some rivets. Below are some pictures for reference. Will hit up Kleen. Are or were you a Gulfstreamer? I am a COR rep on the large cabins. Sent from my iPhone using Tapatalk Worked with Mr K at GAC for a number of years, I’m now at a rotary wing OEM. He and I were also hangar neighbors at KSAV before he moved to the air park. Mr M was my boss for a time. It is interesting, you have old style ailerons. I don’t recall when they changed, but I thought F models had the new style. Note that yours are under cambered. They have higher control force and Were changed when Brittain wing levelers were installed…. You might check the log book and IPC to see if those were swapped out and someone accidentally put the old style on. That might affect rigging on an F. Maybe someone with an F can comment. Quote
Ronnie Pool Posted November 15, 2024 Author Report Posted November 15, 2024 Worked with Mr K at GAC for a number of years, I’m now at a rotary wing OEM. He and I were also hangar neighbors at KSAV before he moved to the air park. Mr M was my boss for a time. It is interesting, you have old style ailerons. I don’t recall when they changed, but I thought F models had the new style. Note that yours are under cambered. They have higher control force and Were changed when Brittain wing levelers were installed…. You might check the log book and IPC to see if those were swapped out and someone accidentally put the old style on. That might affect rigging on an F. Maybe someone with an F can comment.Interesting. I’ve been through the book and there’s no mention of it. There was a factory repair of the wing in 1972 for some undisclosed reason, but no mentor replacement ailerons.Sent from my iPhone using Tapatalk Quote
takair Posted November 15, 2024 Report Posted November 15, 2024 1 minute ago, Ronnie Pool said: Interesting. I’ve been through the book and there’s no mention of it. There was a factory repair of the wing in 1972 for some undisclosed reason, but no mentor replacement ailerons. Sent from my iPhone using Tapatalk The newer ailerons have a double tapered trailing edge. They are near symmetrical. The old ones have an under camber. I thought Fs had the new version. Maybe I’m looking at your picture wrong, do you have more of the ailerons? Alternately, take a look at some other F pictures….some in the classified area show the newer ailerons. The old ailerons actually match the flap profile, the new ones have a different shape. This might lead someone to put on early model ailerons. Not sure what the impact would be on speed, but might be worth a little. Certainly lower control lol on the new one. Quote
Ronnie Pool Posted November 15, 2024 Author Report Posted November 15, 2024 On the photo in flight it looks like the red light for gear up is not on - it should be always when the gear ist up ( at least on the earlier models -TBC) maybe gear does not go all the way up in flight even if it does on ground on jacks? Winner winner chicken dinner! Below is from today’s low pass at speed (my pregnant wife being the camera operating victim. The gear light does go off at higher power settings….because the gear is being sucked down! I rigged them per the book where they are just missing the stops… should they be rigged to where they are against the stops with the bungees under tension? In flight at a lower altitude, I was able to get 145kts with a lot of left rudder in a slip. It also accelerated by 7 knots in a left turn. So I’ll tackle the gear first, then will see about rigging.Sent from my iPhone using Tapatalk 1 Quote
Ronnie Pool Posted November 15, 2024 Author Report Posted November 15, 2024 Winner winner chicken dinner! Below is from today’s low pass at speed (my pregnant wife being the camera operating victim. The gear light does go off at higher power settings….because the gear is being sucked down! I rigged them per the book where they are just missing the stops… should they be rigged to where they are against the stops with the bungees under tension? In flight at a lower altitude, I was able to get 145kts with a lot of left rudder in a slip. It also accelerated by 7 knots in a left turn. So I’ll tackle the gear first, then will see about rigging.Sent from my iPhone using TapatalkForgot the pictureSent from my iPhone using Tapatalk 3 Quote
EricJ Posted November 15, 2024 Report Posted November 15, 2024 What does it do on jack stands? Does it close on jackstands? Quote
Bolter Posted November 15, 2024 Report Posted November 15, 2024 2 hours ago, Ronnie Pool said: Winner winner chicken dinner! Below is from today’s low pass at speed (my pregnant wife being the camera operating victim. The gear light does go off at higher power settings….because the gear is being sucked down! I rigged them per the book where they are just missing the stops… should they be rigged to where they are against the stops with the bungees under tension? In flight at a lower altitude, I was able to get 145kts with a lot of left rudder in a slip. It also accelerated by 7 knots in a left turn. So I’ll tackle the gear first, then will see about rigging. Sent from my iPhone using Tapatalk Isn't there also a spring tension measuement that requires a torque wrench a special Mooney tool. This keeps some linkage over-centered and locked with the correct force, if memory serves. Mooney tools KT8442 and KT8444. I think someone also had a way to do it without the tool, like inserting shims in the spring, then removing them after the adjustment. Not an A&P, so I will be hazy on this. -dan Quote
Ronnie Pool Posted November 15, 2024 Author Report Posted November 15, 2024 Everything looks good on jacks. In the Maintenance Manual the spring tension (bungee) and tool torque relates to gear down. For gear up, the manual has you referencing the stops and checking the spacing.Sent from my iPhone using Tapatalk Quote
skykrawler Posted November 15, 2024 Report Posted November 15, 2024 OK everybody, go get your low speed pass video and find those missing knots. Quote
67 m20F chump Posted November 19, 2024 Report Posted November 19, 2024 (edited) I wanted to put some more numbers on this thread. I have a 67’F. I did 3 way runs at 5500 and 7500 yesterday and was using 22.5”/2600. The speed was 151kts@5500 and 155kts @7500. I have all mods except the J cowl. 2 blade prop. I think I could find a couple more KTS at 8500’ but ran out of time. It’s not a V35 but it is also much less expensive. Edited November 19, 2024 by 67 m20F chump Quote
skykrawler Posted November 19, 2024 Report Posted November 19, 2024 28 minutes ago, 67 m20F chump said: I wanted to put some more numbers on this thread. I have a 67’F. I did 3 way runs at 5500 and 7500 yesterday and was using 22.5/2600. The speed was 151@5500 and 155 at 7500. I don't know what this means - the units are missing. Quote
