varlajo Posted November 11, 2024 Report Posted November 11, 2024 (edited) Currently running an overhauled ALY-8520(R), which appears to be on its last legs. Considering a replacement of both the alternator and the voltage regulator, presently the original OECO. Two questions for the community: * Is there a benefit in changing from ALY-8520(R) to AL12-P70? I can find the former model as an overhauled unit, and the latter as either OH or new. * I am given to understand that Zeftronics R1530B is a better "match" for ALY-8520, and the Plane Power R1224 a better "match" for the AL12-P70. Is this correct? Edited November 11, 2024 by varlajo Quote
Mark942 Posted November 11, 2024 Report Posted November 11, 2024 Hi, I have my old generator and regulator in a box. I replaced with plane-power alternator and regulator in the first few months that I owned my 1964 M20E about six years ago. It was all working fine, I just wanted to start upgrading the plane and this was one of the first things that I did. I'll give these to you free if you want to pay for shipping. I live in Indiana and that old generator is a heavy slug, so I have no idea how much it would cost to ship. Let me know if you are interested. I don't check MooneySpace every night but I usually do 2 or 3 times a week. -mark Quote
varlajo Posted November 11, 2024 Author Report Posted November 11, 2024 16 minutes ago, Mark942 said: Hi, I have my old generator and regulator in a box. I replaced with plane-power alternator and regulator in the first few months that I owned my 1964 M20E about six years ago. It was all working fine, I just wanted to start upgrading the plane and this was one of the first things that I did. I'll give these to you free if you want to pay for shipping. I live in Indiana and that old generator is a heavy slug, so I have no idea how much it would cost to ship. Let me know if you are interested. I don't check MooneySpace every night but I usually do 2 or 3 times a week. -mark Thank you Mark, you are very kind. I will gather a bit more information and come back to you. What model alternator and VR did you end up installing? Quote
JoeM Posted November 11, 2024 Report Posted November 11, 2024 I installed Plane Power alternator and regulator in my 65E (under supervision of A&P/IA of course) and it works very well. Their customer service was fantastic as well. Joe Quote
MikeOH Posted November 11, 2024 Report Posted November 11, 2024 @varlajo Just curious, what symptoms are indicating that your alt/reg "appears to be on its last legs"? Quote
Hradec Posted November 11, 2024 Report Posted November 11, 2024 6 hours ago, JoeM said: I installed Plane Power alternator and regulator in my 65E (under supervision of A&P/IA of course) and it works very well. Their customer service was fantastic as well. Joe One of my friends at the airport one an alternator from plane power. They ended up giving me the certificate for the conversion kit. Plain power sent me an alternator for my 1964 m20e. What part numbers did you install and could you send me pictures of your install? Thanks Quote
varlajo Posted November 11, 2024 Author Report Posted November 11, 2024 4 hours ago, MikeOH said: @varlajo Just curious, what symptoms are indicating that your alt/reg "appears to be on its last legs"? Exhibit A vs. Exhibit B.. 1 Quote
N201MKTurbo Posted November 11, 2024 Report Posted November 11, 2024 I would check the voltage regulator first. 2 Quote
MikeOH Posted November 11, 2024 Report Posted November 11, 2024 I'd check all the wiring for poor connections before spending money on parts. The way the traces look it smacks of an intermittent electrical connection. Maybe the field wire; it opens and the alternator output is going to go to zero and the battery is going to supply the load current (the -22 Amps), then it comes back and the current stabilizes at around 10 Amps after initial spikes to 25-30 Amps. 1 Quote
varlajo Posted November 11, 2024 Author Report Posted November 11, 2024 @N201MKTurbo @MikeOH Thank you both. I am going to do some more diagnostics today. Quote
vik Posted November 15, 2024 Report Posted November 15, 2024 On 11/11/2024 at 2:14 PM, MikeOH said: 'd check all the wiring for poor connections before spending money on parts. Can also be worn brushes. Easy to replace. 1 Quote
