NicoN Posted October 5, 2024 Report Posted October 5, 2024 A colleague said, that the GFC500 provides vertical guidance by using the servo not direct on the elevator but using the elevator trim. Therefore he has the idea that you need 2 Servos to have lateral guidance AND vertical guidance including elevator (auto)trim. I thought you need 3 Quote
ArtVandelay Posted October 5, 2024 Report Posted October 5, 2024 Hmmmm, making it complicated.The trim servo will allow the elevator servo to work with less resistance.3 servos, without the trim servo you would need to adjust the trim manually, but I don’t know anyone who just installed 2 servos. Quote
Pinecone Posted October 5, 2024 Report Posted October 5, 2024 If you have only two servos, the autopilot does not adjust the trim, you need to do that manually. There IS a pitch servo the drives the elevator directly in all installs. Quote
kortopates Posted October 5, 2024 Report Posted October 5, 2024 Many C172’s have only the two servo install. It’s very annoying since anytime you either change airspeed/power or want to change altitude the AP starts annunciating TRIM UP or TRIM DOWN. You become the third servo and you’ll be called on a lot more than you would likely expect. Okay for a trainer that spends most its time in the pattern but quite annoying for an owner flown xctry airplane. Sent from my iPhone using Tapatalk Quote
NicoN Posted October 6, 2024 Author Report Posted October 6, 2024 Right, we also have electrical trim but not auto-trim. So, the answer is: we need THREE servos Next question: We have 2 GI275 installed; do we ONLY need Servos (3) and a mode controller, or do we need another G5 or GI275? Quote
Stanton R Posted October 9, 2024 Report Posted October 9, 2024 If the GI 275 are installed as an ADI and HSI and are mod 1 then you will need the mode controller, servos and install kits. Quote
