SilentT Posted July 29, 2024 Report Posted July 29, 2024 Got a bit of a pickle as I'll be relocating the plane home in the next 4-8 weeks. Adsb doesn't exist in the 84, and while I can use the Adapt system I'd prefer to find a used tail Beacon from yall first before going to ebay etc. or having to fly home without. Quote
R Van Dyck Posted August 2, 2024 Report Posted August 2, 2024 Yes, I have one brand new in the box. I went a different route with my avionics upgrade. Make me an offer Fly Smart Ryan Quote
Mooneymite Posted August 2, 2024 Report Posted August 2, 2024 On 7/29/2024 at 4:37 PM, SilentT said: Got a bit of a pickle as I'll be relocating the plane home in the next 4-8 weeks. Adsb doesn't exist in the 84, and while I can use the Adapt system I'd prefer to find a used tail Beacon from yall first before going to ebay etc. or having to fly home without. Depending on where your tail becon is, you may be better off with a wing-tip mounted Sky Beacon. If your tail becon is on the empenage, no problem, but if your tail beacon is mounted on your rudder, you may have to re-balance the rudder, or at least check it after installation. The Sky Beacon avoids this issue. I've owned both. They both performed flawlessly from the gitgo. Quote
