Dick Denenny Posted April 19, 2024 Report Posted April 19, 2024 I have a '66 M20E with a Ray Jay on it. Should I be able to maintan around 29 to 30 manifold pressure at 12k? Quote
Schllc Posted April 19, 2024 Report Posted April 19, 2024 Without knowing that setup, I would bet you should absolutely see sea level at 12k. simply because if boost tapers off that early, you aren’t getting much benefit at all, before blaming the turbo, check for induction leaks i have two Ray jays on the right side of my Aerostar that are failing to produce full boost and they believe the gap between the fan blade and housing had has eroded, I have full boost up to about 8k and slowly drops off up to 19k, and then stalls at 25-26”. I should see at least 29.2 all the way to 25k. Quote
RescueMunchkin Posted April 21, 2024 Report Posted April 21, 2024 Off topic but why do so many spell it Ray Jay? It's spelled Rajay Quote
RescueMunchkin Posted April 22, 2024 Report Posted April 22, 2024 The Rajay manual says to go full throttle and full rich mixture when in operation. Is that worth doing with the kind of fuel burn of full rich at 12k? Quote
