Pinecone Posted June 6, 2023 Report Posted June 6, 2023 I would appreciate if someone with a Mid body and a lower beacon could take some measurements of the location of the beacon, I would appreciate it. I would like to add a beacon. 1) It is a good safety thing for ground ops to let people know that the engine is running or about to run. And 2), if you leave it on all the time, a quick glance as you walk away lets you know you turned the master off. Quote
N201MKTurbo Posted June 6, 2023 Report Posted June 6, 2023 If you get one of the new LED beacons, which are really just red strobes, they are so small, you could put them just about anywhere. I would pick a location that has good visibility and easy access to the wires. Quote
Ron McBride Posted June 7, 2023 Report Posted June 7, 2023 Look in the tail cone, wiring may be there, also look at the belly, you may find the correct location. Yes go for the led. Quote
Marc_B Posted June 7, 2023 Report Posted June 7, 2023 Not quite measurements, but at least you get a sense of where my beacon is located. A couple of rivets were new and painted over from AP servo install. But beacon was original install location, just replaced with LED. Marc. Quote
Pinecone Posted June 7, 2023 Author Report Posted June 7, 2023 I am going with LED. Not the streamlined one as that was more than full AMU over the round one. This one - https://www.gallagheraviationllc.com/WAT-28V-OR36R2N-Red-LED-Beacon-28-VDC-26-Base_p_177.html What I need is the fore and aft position on the tail cone. I know it goes centerline. Quote
Marc_B Posted June 7, 2023 Report Posted June 7, 2023 Mine is just forward of the static port but I think it’s more of just keeping it away from servos brackets. So I think you have a fairly wide fore-aft area to place it. And it’s also not on the center line but more on the right of center. Quote
Slick Nick Posted Friday at 12:35 AM Report Posted Friday at 12:35 AM @Marc_B I realize this is an older thread, have you got any photos of the backside of the beacon, from inside the tail cone? Quote
Marc_B Posted Friday at 12:54 AM Report Posted Friday at 12:54 AM @Slick Nick I couldn't find any that showed the inside. Its currently at the shop so won't be able to get those for a bit. Quote
Pinecone Posted Friday at 03:13 PM Author Report Posted Friday at 03:13 PM Not sure when the tail will be open, but I will try to remember to get a shot when it is. What are you looking for? Quote
