GaryP1007 Posted November 29, 2022 Report Posted November 29, 2022 Why am I getting the database mismatch message yet showing no mismatch? Sent from my iPhone using Tapatalk Quote
LANCECASPER Posted November 29, 2022 Report Posted November 29, 2022 On 11/29/2022 at 8:52 PM, GaryP1007 said: Why am I getting the database mismatch message yet showing no mismatch? Sent from my iPhone using Tapatalk Expand I believe it's a mismatch between the PFD and MFD 1 Quote
Schllc Posted November 30, 2022 Report Posted November 30, 2022 Sometimes it’s bc old nav data is on the bottom card. most certain way to correct is to format all three cards. make sure you only put nav data on the top card, and reinstall all db on both bottom cards. the new concierge makes you go through the nav data step each time so you could use two top cards, or just don’t reinstall the nav data on the second card updates. this takes a while bc flite charts and the 9 second arc or 4.9 second arc db are huge, but always fixes the problem… 1 Quote
carusoam Posted November 30, 2022 Report Posted November 30, 2022 And if you don’t find the answer… Contact @TrekLawler at BT… -a- Quote
Ragsf15e Posted November 30, 2022 Report Posted November 30, 2022 I have seen that happen after loading new data but not completely restarting after it’s been loaded on both the pfd and mfd. it even shows that the data is the same on aux/sys pages but i had that error until turning everything off and starting up from scratch. Quote
GaryP1007 Posted December 1, 2022 Author Report Posted December 1, 2022 On 11/29/2022 at 11:38 PM, LANCECASPER said: I believe it's a mismatch between the PFD and MFDThat’s exactly what it was. Fixed. Thank you!Sent from my iPhone using Tapatalk 2 Quote
carusoam Posted December 1, 2022 Report Posted December 1, 2022 Great follow up Gary! Thanks for posting the details… Best regards, -a- 1 Quote
