NateZ Posted January 30, 2012 Report Posted January 30, 2012 I don't have a maint. manual available to me just yet. (nor an airplane yet either, working on it) If grabbing the tail from the bottom of the rudder and lifting up (not hard), how much play is acceptable in the trim system if any at all? thanks, Nate Quote
kerry Posted January 30, 2012 Report Posted January 30, 2012 It should have approx 1/4'' of play. Quote
sleepingsquirrel Posted January 30, 2012 Report Posted January 30, 2012 This link could be helpful: http://www.mooney.com/images/pdfs/si-pdf/sim20-35.pdf Quote
nels Posted January 30, 2012 Report Posted January 30, 2012 Quote: sleepingsquirrel This link could be helpful: http://www.mooney.com/images/pdfs/si-pdf/sim20-35.pdf Quote
N601RX Posted January 30, 2012 Report Posted January 30, 2012 Quote: nels I checked out the link and am curious where the aluminum shim, if necessary, is supposed to go. Is it in addition to the spacers or is it strickly a gap filler between the two alum gussets? Just curious as to how this is interpreted. Quote
nels Posted January 30, 2012 Report Posted January 30, 2012 Quote: N601RX I checked out the link and am curious where the aluminum shim, if necessary, is supposed to go. Is it in addition to the spacers or is it strickly a gap filler between the two alum gussets? Just curious as to how this is interpreted. Quote
N601RX Posted January 30, 2012 Report Posted January 30, 2012 Step 5 says between 350060 and 350055, the same place you put the feeler gauge. Its a gap filler. They basically don't want to bend 350055 to the side as the bolt is tightened. Quote
nels Posted January 30, 2012 Report Posted January 30, 2012 Quote: N601RX Step 5 says between 350060 and 350055, the same place you put the feeler gauge. Its a gap filler. They basically don't want to bend 350055 to the side as the bolt is tightened. Quote
lamont337 Posted February 2, 2012 Report Posted February 2, 2012 Quote: NateZ I don't have a maint. manual available to me just yet. (nor an airplane yet either, working on it) If grabbing the tail from the bottom of the rudder and lifting up (not hard), how much play is acceptable in the trim system if any at all? thanks, Nate Quote
sleepingsquirrel Posted February 3, 2012 Report Posted February 3, 2012 http://www.mooney.com/images/pdfs/sb-pdf/sbm20-216.pdf http://www.mooney.com/images/pdfs/sb-pdf/sbm20-62.pdf These links could be helpful. Quote
