Mark Cline Posted May 31, 2022 Report Posted May 31, 2022 Good afternoon, Does anyone know where I can buy (new or overhauled) the engine driven fuel pump for a 1998 M20M? If not, does anyone know where I can have my current fuel pump overhauled? I believe its part number 62021153. Thanks so much, Mark Quote
LANCECASPER Posted May 31, 2022 Report Posted May 31, 2022 28 minutes ago, Mark Cline said: Good afternoon, Does anyone know where I can buy (new or overhauled) the engine driven fuel pump for a 1998 M20M? If not, does anyone know where I can have my current fuel pump overhauled? I believe its part number 62021153. Thanks so much, Mark When you see what the price is for these you will definitely want to have yours rebuilt. I would call Don Maxwell or Dan at LASAR and see who to send it off to. 1 Quote
Rick Junkin Posted June 1, 2022 Report Posted June 1, 2022 8 hours ago, LANCECASPER said: When you see what the price is for these you will definitely want to have yours rebuilt. I was AOG with a suspected fuel pump issue (turned out to be a rookie error involving vapor lock) and was quoted $2,800 for a new pump if I recall correctly. That was 6 years ago. Go with @LANCECASPER's recommendation. Cheers, Rick 1 Quote
carusoam Posted June 1, 2022 Report Posted June 1, 2022 Mark, What seems to be the issue with it? Fuel pumps are known to get resealed which can be a simple quick turn-around… When their seals leak… fuel runs out their drain onto the ground… PP guesses only, not a mechanic… Best regards, -a- 1 Quote
Mark Cline Posted June 1, 2022 Author Report Posted June 1, 2022 It has a small amount of fuel draining out onto the ground, so its time to get this addressed sooner than later. I appreciate all of your responses, and help. I'll get on the phone today. Thanks again! Quote
Mark Cline Posted June 8, 2022 Author Report Posted June 8, 2022 If it helps anyone else out, QAA.com has them available for $1,360. 1 Quote
carusoam Posted June 8, 2022 Report Posted June 8, 2022 Great follow-up Mark! Best regards, -a- Quote
LANCECASPER Posted June 8, 2022 Report Posted June 8, 2022 1 hour ago, Mark Cline said: If it helps anyone else out, QAA.com has them available for $1,360. I hope you have better success with QAA than I had. 1 Quote
Mark Cline Posted June 8, 2022 Author Report Posted June 8, 2022 5 minutes ago, LANCECASPER said: I hope you have better success with QAA than I had. What happened? Quote
LANCECASPER Posted June 8, 2022 Report Posted June 8, 2022 14 minutes ago, Mark Cline said: What happened? Total screw-up on a mag situation. Way too long to go into, but just people who are very difficult to deal with from the top down. Finally American Express helped get me part of the money. Poor workmanship, complete screw-up on the shipping, no one would take responsibility. I've said many times since then that I wouldn't personally trust them to overhaul parts for my lawn mower. I'm sure others have had better experiences since they are still in business. 2 Quote
Mark Cline Posted June 25, 2022 Author Report Posted June 25, 2022 Follow up: Got the pump from QAA, its installed on the plane, and it is working great. The pressure had to be turned up quite a lot from the setting out of the box, but that was not a big deal. The new fuel pump made a big difference in my FF values (now much lower, and closer to the POH values). Apparently my old one was sucking in some air and affecting my FF values. 1 Quote
carusoam Posted June 26, 2022 Report Posted June 26, 2022 Great follow-up Mark! Small air leaks will definitely inflate the FF number… People often see air bubbles when diagnosing their fuel injectors for problems… The baby food jar test… Best regards, -a- Quote
