Ulysse Posted March 19, 2022 Report Posted March 19, 2022 (edited) My plane has a bose connector on both the pilot and copilot side (picture attached) I wonder if this was factory installed ? Where can I find the electrical wiring ? Edited March 19, 2022 by Ulysse Quote
LANCECASPER Posted March 19, 2022 Report Posted March 19, 2022 3 hours ago, Ulysse said: My plane has a bose connector on both the pilot and copilot side (picture attached) I wonder if this was factory installed ? Where can I find the electrical wiring ? I had a '97 Encore and on the factory invoice it showed a Bose headset with interface installed and it looked just like yours. Quote
Ulysse Posted March 19, 2022 Author Report Posted March 19, 2022 Thank you. Any idea where to find the wiring diagram? Quote
LANCECASPER Posted March 19, 2022 Report Posted March 19, 2022 51 minutes ago, Ulysse said: Thank you. Any idea where to find the wiring diagram? Google is your friend Quote
Ulysse Posted March 19, 2022 Author Report Posted March 19, 2022 (edited) I meant, how is it wired in the Mooney? The reason I am asking is that since I replaced the audio panel, i cannot hear if I use the lemo plug. I can however transmit. Edited March 19, 2022 by Ulysse Quote
LANCECASPER Posted March 19, 2022 Report Posted March 19, 2022 2 hours ago, Ulysse said: I meant, how is it wired in the Mooney? The reason I am asking is that since I replaced the audio panel, i cannot hear if I use the lemo plug. I can however transmit. If it worked before you replaced the audio panel, I would talk to the people that replaced your audio panel Quote
Ulysse Posted March 19, 2022 Author Report Posted March 19, 2022 33 minutes ago, LANCECASPER said: people that replaced your audio He is 10000km away unfortunately. I wanted to avoid a trip to another avionics shop and fix it myself. Quote
Aerodon Posted March 19, 2022 Report Posted March 19, 2022 The drawing shows the Lemo wired in parallel with the jacks (more common). I see a switch on your installation, so either it is a many pole double throw, or a SPDT switch that controls a relay. And (unfortunately) I can see an avionics technician not understanding this and running a new wire from the audio panel to the jacks / Lemo. When you say you can't hear, are you talking about the sidetone when transmitting or the audio from the radio? Or both? Aerodon Quote
Ulysse Posted March 20, 2022 Author Report Posted March 20, 2022 2 hours ago, Aerodon said: both Both Quote
larryb Posted March 20, 2022 Report Posted March 20, 2022 (edited) The switch is just for the mic circuit. Otherwise both the standard and Lemo are wired in parallel. You should be able to hear the radio regardless of the switch setting. You will only hear your own mic if the switch is in the proper position. If you never connected both bose and standard you would not need the switch. But if you have a bose headset and a separate mic for an O2 mask you would need the switch. Edited March 20, 2022 by larryb 2 Quote
Aerodon Posted March 20, 2022 Report Posted March 20, 2022 I was debating whether I should install both Lemo and jacks, now you have given another reason (O2 mask mic). And just this morning my friend called to borrow my Bose A20's because his failed and he needs a Lemo headset. Don Quote
LANCECASPER Posted March 21, 2022 Report Posted March 21, 2022 On 3/19/2022 at 9:04 PM, Aerodon said: I was debating whether I should install both Lemo and jacks, now you have given another reason (O2 mask mic). And just this morning my friend called to borrow my Bose A20's because his failed and he needs a Lemo headset. Don This also works for an oxygen mask mic if you only have lemo plugs. https://www.pilot-usa.com/pa-100b.html 1 Quote
kortopates Posted March 21, 2022 Report Posted March 21, 2022 The switch is just for the mic circuit. Otherwise both the standard and Lemo are wired in parallel. You should be able to hear the radio regardless of the switch setting. You will only hear your own mic if the switch is in the proper position. If you never connected both bose and standard you would not need the switch. But if you have a bose headset and a separate mic for an O2 mask you would need the switch.Actually mine works beautifully without the switch. Bose is always plugged into Lemo and when I am using my mask, i have the mask mike plugged in as well. All i need to do additionally is change the squelch higher for mask, but my bose isn’t adding any nose.I assume both mike inputs are wired in parallel but i didn’t install it.Sent from my iPhone using Tapatalk Quote
