Prop Forward on Final
HopePilot
Quote: DaV8or
Just curious, have those that don't touch anything except gear until final tried an experimental go around with cruise mixture and cruise prop? I haven't, so I can't comment on how well this works or doesn't work, but I'm wondering if it works just fine or not. By not adjusting those things, it assumes that you will always remember to correct those things in the event of a go-around. Seems reasonable to test and see what happens if you don't.
Link to comment
Share on other sites
If it's not there already, I push Mixture and Prop forward when I deploy Takeoff Flaps on downwind. At shorter fields, that is immediately followed by gear down then lots of cranking on the trim wheel. On true Short Fields, I need to start
Link to comment
If it's not there already, I push Mixture and Prop forward when I deploy Takeoff Flaps on downwind. At shorter fields, that is immediately followed by gear down then lots of cranking on the trim wheel. On true Short Fields, I need to start setting u
Link to comment
If it's not there already, I push Mixture and Prop forward when I deploy Takeoff Flaps on downwind. At shorter fields, that is immediately followed by gear down then lots of cranking on the trim wheel. On true Short Fields, I need to start setting up
Link to comment
If it's not there already, I push Mixture and Prop forward when I deploy Takeoff Flaps on downwind. At shorter fields, that is immediately followed by gear down then lots of cranking on the trim wheel. On true Short Fields, I need to start setting up before I e
Link to comment
If it's not there already, I push Mixture and Prop forward when I deploy Takeoff Flaps on downwind. At shorter fields, that is immediately followed by gear down then lots of cranking on the trim wheel. On true Short Fields, I need to start setting up before I enter t
Link to comment
If it's not there already, I push Mixture and Prop forward when I deploy Takeoff Flaps on downwind. At shorter fields, that is immediately followed by gear down then lots of cranking on the trim wheel. On true Short Fields, I need to start setting up before I enter the pattern.
Link to comment
Seems to happen in both "Post Reply" and "Quick Reply." I hit "submit" and there are four, six, ten, twelve posts. Like this time, it seemed to make a new post with each letter that I typed. But still, for the price, this forum can't be beat!
I swear, I keep my fingers away from the "Enter" key . . . . .
Link to comment
