Htmlkid Posted January 20, 2021 Report Posted January 20, 2021 Im having issues when I use to pilots push to talk button. The volume is perfect hering ATC and also my copilot but when I push the button I get static and my voice is super loud in my headset.... any ideas? Quote
47U Posted January 20, 2021 Report Posted January 20, 2021 Have you tried a different headset? Can your copilot position transmit? Is it the same from that position? Is it the same on both radios? If it's only one radio, it could be the side-tone needs adjustment... Not an avionics guy.... 1 Quote
RobertGary1 Posted January 25, 2021 Report Posted January 25, 2021 Check the solder on the key line. Maybe wiggle it around and see if you hear a difference. Quote
Don Heene Posted January 25, 2021 Report Posted January 25, 2021 I almost have that problem, when I get close to the airport ATC gives me instructions that's the time my wife is screaming in the head set and I can't hear ATC 3 Quote
FastTex Posted January 26, 2021 Report Posted January 26, 2021 13 hours ago, Don Heene said: I almost have that problem, when I get close to the airport ATC gives me instructions that's the time my wife is screaming in the head set and I can't hear ATC LOL. Use the magic "ISO" button!!! Quote
jaylw314 Posted January 26, 2021 Report Posted January 26, 2021 On 1/20/2021 at 1:56 PM, Htmlkid said: Im having issues when I use to pilots push to talk button. The volume is perfect hering ATC and also my copilot but when I push the button I get static and my voice is super loud in my headset.... any ideas? Sounds like you're talking about the "sidetone" volume. Depends on the radio, I know the GNS 530 has a menu option to adjust the sidetone volume. Quote
RobertGary1 Posted January 27, 2021 Report Posted January 27, 2021 11 hours ago, jaylw314 said: Sounds like you're talking about the "sidetone" volume. Depends on the radio, I know the GNS 530 has a menu option to adjust the sidetone volume. That’s the more/less static button? Quote
