NZMooney Posted December 22, 2020 Report Posted December 22, 2020 Hi from New Zealand, I have a question that may have been answered on the forum previously, forgive me in advance.. We have a '64 M-20C on maintenance, s/n 2802 which has rotten flaps. We also have access to flaps off an M-20 E which have been refurbished. So the question is, can the 240000 flaps be replaced with the 240014 flaps? They are of different construction with different fairings but were fitted to C's from s/n 2923 on. Thank you. Pete Garlick Northland Aviation Whangarei New Zealand
RLCarter Posted December 23, 2020 Report Posted December 23, 2020 How, 4 hrs and no comments. Not sure about interchangeability but welcome aboard
NZMooney Posted December 23, 2020 Author Report Posted December 23, 2020 Thank you. I'd say it's the dash. Gives me away as not quite an aficionado. 1
47U Posted December 23, 2020 Report Posted December 23, 2020 18 hours ago, NZMooney said: So the question is, can the 240000 flaps be replaced with the 240014 flaps? They are of different construction with different fairings but were fitted to C's from s/n 2923 on. NZ, I’m not an expert, only having exposure to my ‘63C. Regardless... I compared the illustrations for those two flap part numbers and see some differences. The torque tube connection/linkage is different, and the hinge point bearing blocks are also different. I’m not even sure if the hinge spacing is the same. The early flaps also had skin around the leading edge and later flaps used an extrusion. That difference might affect the way the flap seals against the wing skin when the flaps are retracted, but again, I only have hands-on with my C. The newer style is the top pic. Although, the middle pic should be what I have installed, the scale of the arm on the torque tube doesn’t appear to be representative as compared to my airplane (bottom pic). Good luck... 1
carusoam Posted December 25, 2020 Report Posted December 25, 2020 welcome aboard Pete! Part numbers are going to be important... The real question is how important... We have two guys I can think may be helpful to the conversation... One knows the most Mooney details... the other has collected the most number of ailerons... @M20Doc and @Alan Fox Merry Christmas and happy holidays! Best regards, -a-
PT20J Posted December 25, 2020 Report Posted December 25, 2020 Just email technicalsupport@mooney.com. They are very responsive to specific questions in my experience. Skip 1
Alan Fox Posted December 25, 2020 Report Posted December 25, 2020 They are different , everything changes after 64 ... 1
