dan nephin Posted November 19, 2020 Report Posted November 19, 2020 I had the gfc 500 installed in my 231 and now the trim switch is intermittent when using it to trim for takeoff. does anyone have an exploded view of this switch? I’ve searched the downloads and found that it is a combination of 3 micro switches and would like to get deeper into this before going to the avionics shop. Thanks Dan
carusoam Posted November 19, 2020 Report Posted November 19, 2020 @dan nephinDan which switch are you using? Many have reported leaving their old BK trim switch in place... Best regards, -a-
dan nephin Posted November 19, 2020 Author Report Posted November 19, 2020 This is the old oem switch with the bar on top to actuate.
carusoam Posted November 20, 2020 Report Posted November 20, 2020 Good news then... Those little micro switches can be replaced easily... Now to find where those details are.... I’ll try the search... see if I can find them... Best regards, -a- This gets you a bit closer... https://mooneyspace.com/search/?q=Trim switch micro&updated_after=any&sortby=relevancy&search_and_or=and
Bob Weber Posted November 21, 2020 Report Posted November 21, 2020 On 11/19/2020 at 6:57 PM, dan nephin said: This is the old oem switch with the bar on top to actuate. Could you email a pic to bobweber@webairconsulting.com the bar on top is intriguing, sounds like a Century switch. You can also call me at 616 822 1999
carusoam Posted November 22, 2020 Report Posted November 22, 2020 Dan, In case you don’t recognize Mr. Weber... Bob Weber is a trusted advisor / supplier to many MSers for their AP needs... Go MS! Best regards, -a- 1
dan nephin Posted November 22, 2020 Author Report Posted November 22, 2020 Many thanks to carusoam and bob Weber for their help so far. I plan to get to the hangar tomorrow and get a pic of the switch. Reading further on the trim switch thread I found that I may be able to adjust it, so that will be the next step happy thanksgiving! 1
