Speed Merchant Posted August 15, 2020 Report Posted August 15, 2020 Has anyone installing 205 onboard gear doors on a 201? Looking to eak out a few more knots. Anyone done this? Quote
carusoam Posted August 16, 2020 Report Posted August 16, 2020 There is an ovation in Europe getting parted out... You may look there for these parts... Best regards, -a- Quote
Speed Merchant Posted August 16, 2020 Author Report Posted August 16, 2020 Thanks- have any contact for the salvage yard? Do you know if anyone has installed them on a J model? Regards Quote
gsxrpilot Posted August 16, 2020 Report Posted August 16, 2020 I may have a set to sell in a month or so. Quote
Speed Merchant Posted August 16, 2020 Author Report Posted August 16, 2020 Have you ever seen them installed on 201s? Quote
kortopates Posted August 16, 2020 Report Posted August 16, 2020 I would expect cost at several thousand, well over 4. New parts would probably run close to 2K a side. There is bell crank to install whose hardware penetrates the spar and tank. I have no idea how feasible it would be to retrofit that (perhaps a helicoil insert) since your spar didn't come from the factory ready for that. The gear door itself isn't an issue. I'd get a sheet metal guy to take a look and give you a better idea if you're really want them. Quote
carusoam Posted August 16, 2020 Report Posted August 16, 2020 The Euro Ovation connection.... -a- Quote
Speed Merchant Posted August 17, 2020 Author Report Posted August 17, 2020 8 hours ago, gsxrpilot said: I don't think I have. New territory- wish I had some pictures of the installation. Quote
Speed Merchant Posted August 17, 2020 Author Report Posted August 17, 2020 20 hours ago, carusoam said: There is an ovation in Europe getting parted out... You may look there for these parts... Best regards, -a- Thanks I contacted him about them. 1 Quote
Speed Merchant Posted August 17, 2020 Author Report Posted August 17, 2020 9 hours ago, gsxrpilot said: I may have a set to sell in a month or so. Do you have the complete system? Quote
Speed Merchant Posted August 17, 2020 Author Report Posted August 17, 2020 4 hours ago, kortopates said: I would expect cost at several thousand, well over 4. New parts would probably run close to 2K a side. There is bell crank to install whose hardware penetrates the spar and tank. I have no idea how feasible it would be to retrofit that (perhaps a helicoil insert) since your spar didn't come from the factory ready for that. The gear door itself isn't an issue. I'd get a sheet metal guy to take a look and give you a better idea if you're really want them. So the mechanism penetrates the spar web and also goes into the fuel tank? Quote
jetdriven Posted August 17, 2020 Report Posted August 17, 2020 I’ve already contacted the Swiss Mooney guy for the 205 gear doors and parts. It does look like a huge job for the benefit Quote
gsxrpilot Posted August 17, 2020 Report Posted August 17, 2020 2 hours ago, Speed Merchant said: Do you have the complete system? No, just the doors. I'm putting double puck brakes on my 252 and that requires different doors. Quote
kortopates Posted August 17, 2020 Report Posted August 17, 2020 4 hours ago, Speed Merchant said: So the mechanism penetrates the spar web and also goes into the fuel tank? A bolt to attach a bellcrank penetrates the spar into the tank. Quote
