xcrmckenna Posted July 17, 2020 Report Posted July 17, 2020 Trim switch has stopped working again. The down trim micro switch crapped out. This time the hangar fairy is looking to install a six wire connector where the wires come out of the left side yoke handle and goes into the yoke shaft. I want the smallest six wire connector I can find, so it doesn’t get in the way and rub on my leg or knee pad. I’m going to use 24 gauge wire to get as slim of a connect I can find. Sent from my iPhone using Tapatalk Quote
chriscalandro Posted July 17, 2020 Report Posted July 17, 2020 (edited) 6 pin Lemo. also, are you sure you want to use 24g for that? Edited July 17, 2020 by chriscalandro Quote
N201MKTurbo Posted July 17, 2020 Report Posted July 17, 2020 I would look at mil-dtl-83513 connectors. 1 Quote
larryb Posted July 17, 2020 Report Posted July 17, 2020 I would use a mini molex plug. Or a d-sub if you can handle the shell size. Quote
xcrmckenna Posted July 17, 2020 Author Report Posted July 17, 2020 6 pin Lemo. also, are you sure you want to use 24g for that? Dang I didn’t even think about a Lemo connector. I ordered a deutsch connector. I decided to go with the 20g. If this doesn’t work then I’ll use a Lemo connector. Sent from my iPhone using Tapatalk Quote
xcrmckenna Posted July 17, 2020 Author Report Posted July 17, 2020 I would use a mini molex plug. Or a d-sub if you can handle the shell size. I didn’t realize they made a mini molex plug. That might work. I ordered a deutsch connector and see how that works out first. Sent from my iPhone using Tapatalk Quote
