Mooney-Shiner Posted August 31, 2020 Author Report Posted August 31, 2020 Just now, carusoam said: Sorry, I didn’t catch the siri-ism... Best regards, -a- No worries, as you see above I understood your point. I didn't see the sealant separation. I did traced the leak from the inside of the wheel well up to the aft section of the tank. I speculate that the leak ordination point is there somewhere. 1
carusoam Posted August 31, 2020 Report Posted August 31, 2020 Often, the top of the tank sees the hottest temps in the sun... if you only lose a gallon, and it stops leaking... it will probably be a top seem or rivet... You may find a lot of blue stain... that may require cleaning before pin pointing... When getting serious about solving the leak... there are procedures for that too... Best regards, -a- 2
