shawnd Posted June 14, 2020 Report Posted June 14, 2020 Searched the forums prior to asking. Folks here have reported that M20K have Scott style O2 connectors. Is this the norm among all M20K including 252s? Surprisingly, my AFM supplement doesn't mention the type of connector. I have asked my shop for a pic so when it comes in, I will post here. Trying to decide which one of these it is so I can buy 4 of the right kind: https://www.preciseflight.com/general-aviation/shop/kit/all-one-connector-kit/ Quote
PJClark Posted June 14, 2020 Report Posted June 14, 2020 Scott connector. It's the green one in that Precise flight photo 1 1 Quote
carusoam Posted June 15, 2020 Report Posted June 15, 2020 Be sure to know what you have... they are close enough to feel right and look right... and then come apart while you are not looking.... It really helps to know what the PO was buying... Best regards, -a- Quote
shawnd Posted June 15, 2020 Author Report Posted June 15, 2020 20 minutes ago, carusoam said: Be sure to know what you have... they are close enough to feel right and look right... and then come apart while you are not looking.... It really helps to know what the PO was buying... Best regards, -a- Any ideas where I can lookup what type of connectors they are? AFM wasn't helpful (surprisingly) and no receipts nor logbook entries indicating connector type. From the kit picture - it seems like they are of different enough widths that they would be easy to distinguish between them. And the CPC and Scott connector shapes are unique. Quote
smwash02 Posted June 15, 2020 Report Posted June 15, 2020 @shawnd Mooney uses Scott connectors on all their built in systems as others have said here. Exceptions would be if you used an aftermarket system, but the only one I know of (Precise Flight) also uses a Scott connector. Attached is a snip from the M20K service manual referencing 'Scott connector'. I've also attached a photo of the port and connector for the common types. Personally, I think the CPC and Scott look very different. Are you needing replacement ports or are you trying to plug a canula/mask into the system? 1 1 Quote
carusoam Posted June 15, 2020 Report Posted June 15, 2020 There are two common types around MS... Somewhere around here somebody posted pics of the parts side by side... Small changes in diameter and length of the insert piece... Somebody had bought both brands to prove to himself which one he definitely had... PP fuzzy memories only... wish I could find the thread... Best regards, -a- 1 Quote
shawnd Posted June 15, 2020 Author Report Posted June 15, 2020 Sweet - thanks @smwash02. That makes me more confident about the Scott connectors. I do not believe the system was replaced with an aftermarket one. I am just trying to replace the missing cannulas/masks and use it for the ferry flight to Seattle. Quote
shawnd Posted June 15, 2020 Author Report Posted June 15, 2020 3 minutes ago, carusoam said: There are two common types around MS... Somewhere around here somebody posted pics of the parts side by side... Small changes in diameter and length of the insert piece... Somebody had bought both brands to prove to himself which one he definitely had... PP fuzzy memories only... wish I could find the thread... Best regards, -a- I think I found what you are referring to: 1 Quote
smwash02 Posted June 15, 2020 Report Posted June 15, 2020 @shawnd Scott connectors will do the trick for you. If it's the one in your signature (252XM), I was looking at that one and my notes say the bottle was out of hydro, but that was 6+ months ago. Just a heads up. Quote
carusoam Posted June 15, 2020 Report Posted June 15, 2020 LT is still around MS... I got to fly in loose formation with him leaving the last Mooney Summit.... And Seth, and Alan.... Best regards, -a- Quote
shawnd Posted June 15, 2020 Author Report Posted June 15, 2020 So looks like @L. Trotter was able to fix the leaks with the new Scott connectors he ordered. That's promising. Once I get the photo back from the shop tomorrow to double check the type (x-fingers), I will give Precise Flight a call. 1 Quote
gsxrpilot Posted June 15, 2020 Report Posted June 15, 2020 You can double check all you like. But in the end all Mooneys with built in O2 use Scott connectors. 1 1 Quote
shawnd Posted June 15, 2020 Author Report Posted June 15, 2020 Just now, gsxrpilot said: You can double check all you like. But in the end all Mooneys with built in O2 use Scott connectors. Just to make sure the previous owners didn't replace it with some weird aftermarket one Quote
shawnd Posted June 16, 2020 Author Report Posted June 16, 2020 Yep, sure looks like the Scott connector. Quote
L. Trotter Posted June 22, 2020 Report Posted June 22, 2020 On 6/14/2020 at 5:54 PM, shawnd said: Searched the forums prior to asking. Folks here have reported that M20K have Scott style O2 connectors. Is this the norm among all M20K including 252s? Surprisingly, my AFM supplement doesn't mention the type of connector. I have asked my shop for a pic so when it comes in, I will post here. Trying to decide which one of these it is so I can buy 4 of the right kind: https://www.preciseflight.com/general-aviation/shop/kit/all-one-connector-kit/ You want the Scott connector. I had two separate problems in my Acclaim oxygen delivery. 1- I visited Precise Flight in Oregon. I took perhaps 20 green Scott connectors and found several that worked without a leak. I'm not not sure why some of the connectors leaked. The folks at Precise Flight felt it was a combination of manufacturing variances between both the connector and valve outlet-one a little small, the other a little big. I was about to replace the valve in the plane (not a small task) until I tried different Scott connectors. Of note, after talking with far too many people about this leak issue, I could find no one who had experienced complete failure of a valve requiring replacement. Not that it cant happen...it's just extremely rare. 2- I used hospital O2 tubing as part of the nasal cannula. Most hospital O2 tubing has raised internal "ribs" inside the tubing (I suppose to keep it from kinking). This internal raised area allows O2 to leak around any connection points. specifically at the Scott connector. 1 Quote
shawnd Posted June 23, 2020 Author Report Posted June 23, 2020 I just received my 4 sets of o2 kits from Precise today. I need 2 for the ferry flight so hoping at least 2 of the 4 work out. Thanks folks for all the help! Quote
