n5756k Posted February 7, 2020 Report Posted February 7, 2020 I have a 1984 Mooney M20J and need a Radio Master Switch. Does anyone have one to sell? Tom Moquin 847.340.2325 Quote
Oldguy Posted February 7, 2020 Report Posted February 7, 2020 You can probably get a new one ($$$) from a MSC. Otherwise you might check with @Aerodon, @Alan Fox or @SheryLoewen for a used one. Quote
n5756k Posted February 7, 2020 Author Report Posted February 7, 2020 thank you for getting back to me. Quote
Oldguy Posted February 7, 2020 Report Posted February 7, 2020 40 minutes ago, n5756k said: thank you for getting back to me. Gotta help my older brother. 1984 J - N5767Z 1 Quote
Yetti Posted February 8, 2020 Report Posted February 8, 2020 (edited) Are you sure you need a switch and not a relay? Asked another way are you seeing that you can't turn the radios off via the switch. Edited February 8, 2020 by Yetti 1 Quote
carusoam Posted February 9, 2020 Report Posted February 9, 2020 Tom, As the Yetti has pointed out... It may be the relay, not working... Something to test before spending the big bucks on the CB/switch. PP thoughts, not a mechanic... Best regards, -a- Quote
201Mooniac Posted February 10, 2020 Report Posted February 10, 2020 I have one from a 1980 M20J that was replace a few years ago. It worked fine at the time but the ink in the engraving is pretty warn. If you are interested, let me know and I can get you a picture. Quote
n5756k Posted February 11, 2020 Author Report Posted February 11, 2020 Great, please call me at 847 340-2325 Tom Quote
n5756k Posted February 12, 2020 Author Report Posted February 12, 2020 Yes, please, I want it. Tom Moquin tel 847-340-2325 Quote
carusoam Posted February 12, 2020 Report Posted February 12, 2020 @201Mooniac message above... ^^^^ -a- Quote
201Mooniac Posted February 12, 2020 Report Posted February 12, 2020 Sorry for the delay. I'm on business travel and will be back and can call on Friday morning. Quote
n5756k Posted February 12, 2020 Author Report Posted February 12, 2020 I might still be in the Mayo Clinic, please call if I don’t answer please leave a message I will call you back. Yes, please, I want it. Tom Moquin tel 847-340-2325 Quote
PeytonM Posted February 29, 2020 Report Posted February 29, 2020 My relay failed on my 89 J a few years ago. The symptom was that the radios came on when you turned on the Master Switch. The Radio Master position “on” or “off” was irrelevant. I understand that the relay fails this way so that you always have radios; makes sense. I can check my records on this. Many A&Ps unfamiliar with the Mooney setup will try suggest adding a second Radio Master switch Quote
