Knuckledragger00 Posted August 12, 2019 Report Posted August 12, 2019 I am still fairly new to the G1000. When I first got my plane I had no problem with the lean function. I would hit lean and then turn back mixture until it peaked. I could go LOP and it would show a minus next to the number that would increase if I continued to lean. If I wanted ROP of peak it show a plus sign after turn richer after hitting peak. However, I recently had the GIA 63W (WAAS upgrade) installed and now I am not able to use this feature. When I now hit lean now I can’t seem to ever get to the highest point where it would start counting back. I don’t want to get too much past 1650 but I wonder if someone could explain the best technique for using the lean feature? Thanks in advance! Quote
carusoam Posted August 12, 2019 Report Posted August 12, 2019 KD, Is this for your TNIO550? Sounds like part of the WAAS upgrade was a software update... There is a thread around here that may cover the details related to the GIA63W upgrade... 1) This is the short list, where I thought your challenge would get mentioned... 2) there there is a broader list... https://mooneyspace.com/search/?q=GIA63W I didn’t see anyone with a shared experience like yours... so it could be good news of finding the right button... Since leaning with TIT is a critical function for the TNs... it’s got to be there... While waiting for a G1000 user with the answer to arrive.... @Danb (Bravo owner) may be around here.... consider contacting @TrekLawler who can often be found easily at BT... or @Pmaxwell.... If the button has a mechanical type challenge... Some Big G hardware often does this... button exercise sometimes makes the button work.... Good luck with your next steps... PP thoughts only, not a mechanic or g1000 user... Best regards, -a- 1 Quote
Knuckledragger00 Posted August 12, 2019 Author Report Posted August 12, 2019 Car, How far do you lean in relation to TIT before you see it peak out typically? Maybe I am not going far enough? Just scared to get it too hot! Quote
exM20K Posted August 12, 2019 Report Posted August 12, 2019 (edited) My procedure for 29x2500 Lean O'Peak: Big Mixture Pull back to about 16 GPH or whatever it takes to get a noticeable reduction in power. Hit lean button on engine page. Add fuel slowly until peak (usually 1705-1715). Re-lean to 50-65 LOP The Big Mixture Pull gets you through the detonation danger zone (Red Box, for those who have taken the APS Red Pill) quickly. Brief time spent above 1700 while establishing peak shouldn't hurt anything. If you were getting peak at 1650' on a TSIO550 running 2500 rpm and 28-29", something was not right. One other things to check: is your fuel flow accurate? Mine had a dirty connector and was reading low. And TIT probes will read low when they are failing. -dan Edited August 12, 2019 by exM20K 2 Quote
carusoam Posted August 12, 2019 Report Posted August 12, 2019 Leaning procedure for turbos is always a challenge... once done to document FF vs. TIT for their ship... people use the ‘big pull’ technique after that... -Dan has arrived! See his explanation above.... Best regards, -a- 1 Quote
Danb Posted August 12, 2019 Report Posted August 12, 2019 KD I generally don’t use the auto lean function but have, not since my WAAS upgrade I don’t believe. I’d lean must faster to mitigate time above 1600, I also don’t do the big pull but would rather than hang around with high TIT, once you have a good idea of how far to lean I’d get there quicker. I don’t have gami’s but can run 30-50 LOP ok, but don’t. Good luck and let us know your final numbers. 2 Quote
Danb Posted August 12, 2019 Report Posted August 12, 2019 KD I didn’t see dans above procedure above looks like good advice. Quote
carusoam Posted August 12, 2019 Report Posted August 12, 2019 Dan, Any insight on the G1000 auto lean question? Best regards, -a- Quote
Danb Posted August 12, 2019 Report Posted August 12, 2019 Anthony I’d assume if the software is set up properly it should work , I had numerous issues with things not working I had to have the software reconfigured 1 Quote
exM20K Posted August 12, 2019 Report Posted August 12, 2019 On 8/12/2019 at 7:08 PM, carusoam said: Dan, Any insight on the G1000 auto lean question? Best regards, -a- Not sure about auto-lean. The most recent software does show degrees from peak TIT, but it doesn’t leave a mark at peak ETG for each cylinder. Since I care most that the richest cylinder is at least 50’ LOP, and since they all do peak at about the same fuel flow, I just take a picture of the display at peak TIT to be sure. 2 Quote
Knuckledragger00 Posted August 12, 2019 Author Report Posted August 12, 2019 Wow this is incredibly useful info! I wonder if it is different due to the software update? That actually makes the most sense. Never heard of the big pull method but I plane on trying it! Quote
Robert C. Posted August 25, 2019 Report Posted August 25, 2019 The WAAS upgrade definitely involves a software update but I don’t know what the connection might be to the disappearance of the lean assist function. Guess I was lucky as it never went away for me and I still have the peak markings for each cylinder and the delta from last to peak in the information box. Sorry I can’t be more helpful. Robert 2 Quote
