Hotel_India_Juliet Posted July 30, 2019 Report Share Posted July 30, 2019 I regularly see fuel spilling out around the right fuel filler on takeoff. I have tried tightening the screw on the filler cap, and I never fill too full, leaving at least 1/2" space below the rim of the filler. All to no avail: the fuel just flies out for approx the first 500ft of the climb. At the price of 100ll, I hate to see the $$ going overboard, and it also leaves messy streaks over my wing. This only seems to happen to the right tank, rarely have I seen it on the left side. Has anyone else had this issue? If so, how did you fix it? Quote Link to comment Share on other sites More sharing options...
carusoam Posted July 30, 2019 Report Share Posted July 30, 2019 Welcome aboard,HIJ... There is a maintenance procedure in the manual for that... There is also a thread that might interest you... Best regards, -a- Quote Link to comment Share on other sites More sharing options...
Pasturepilot Posted July 30, 2019 Report Share Posted July 30, 2019 Time for new o-rings on the cap? Quote Link to comment Share on other sites More sharing options...
carusoam Posted July 30, 2019 Report Share Posted July 30, 2019 Either o rings or proper cap set-up.... There are two O-rings per cap. One is easily visible, the other very well hidden... Also know there are some older fuel necks that may be rusty... enough to have holes through them... what year is the C in question? Mine was a 65... with the full rust challenge... rain water can enter the tanks if fuel can escape... use caution... Best regards, -a- Quote Link to comment Share on other sites More sharing options...
ArtVandelay Posted July 30, 2019 Report Share Posted July 30, 2019 Is there some resistance when securing the cap (pushing the tab down), if not you need to adjust it?Tom Quote Link to comment Share on other sites More sharing options...
Hank Posted July 31, 2019 Report Share Posted July 31, 2019 Tightening the fuel cap requires taking out the lower cotter pin, tightening the nut, testing the fit until you're happy, then replacing the used cotter pin with a new one. Good luck! Took me a couple tests when I installed the blue fluorosilicone orings. Quote Link to comment Share on other sites More sharing options...
Browncbr1 Posted July 31, 2019 Report Share Posted July 31, 2019 Switch caps and see if the problem follows the cap 2 Quote Link to comment Share on other sites More sharing options...
