1967 427 Posted May 26, 2019 Report Share Posted May 26, 2019 (edited) I've owned my 66 C for about 7 years, loved everything about it. But as time marches on, gravity has been taking its toll on my headliner. As a started to investigate what is failing, I assumed the fibers from the headliner were deteriorating. To my surprise I found the headliner glued directly to the foam insulation. The insulation Is crumbling away from age. Why would the shop (some interior shop in San Diego that no longer exists, no surprise) glue it directly to the insulation? Was this a normal way of doing this? Were they trying to save weight? Were they cheap? I would assume that the right way would be to glue the fabric to a piece of flat .063 thick ABS. This piece could then be held in place by all the trim. Since the insulation is failing it will also need to be replaced. I found a link to 1/2 inch closed cell soundproofing foam on another thread, which seems to be the best choice. Any other suggestions? Edited May 26, 2019 by 1967 427 Title error Quote Link to comment Share on other sites More sharing options...
Rwsavory Posted May 26, 2019 Report Share Posted May 26, 2019 I am sure there are many ways to do this. When replacing my baggage door fabric and liner I used .020 aluminum as a backing material. I glued foam to it and then covered it with vinyl fabric that had FAA fire certification (All American Naugahyde from Sailrite). The aluminum was very easy to work with. 3 Quote Link to comment Share on other sites More sharing options...
Prior owner Posted May 26, 2019 Report Share Posted May 26, 2019 1967- I'm not familiar with your particular year, but the older models had metal bows to form the curvature at the roof. It looks like the later models didn't have bows, which would mean that the only way (other than to use a plastic headliner) to get the fabric to conform and stay conformed to the curvature, would be to glue it all in place. I doubt it was ever expected to last as long as it has! Rwsavory- thanks for posting the baggage door pics- I have saved that bit for last and I think I'm going to do the same thing with mine... Quote Link to comment Share on other sites More sharing options...
carusoam Posted May 27, 2019 Report Share Posted May 27, 2019 Looks like 67’s 66 ceiling was done in a modern automotive way... After about 20years the foam oxidizes and degrades, leaving the fabric sagging... RWS... nice job on the baggage door... My 65C had a cardboard base with vinyl covering over it... and some fancy spring clips holding it in location... The aluminum piece looks like a premium way to go... Best regards, -a- 1 Quote Link to comment Share on other sites More sharing options...
67 m20F chump Posted May 27, 2019 Report Share Posted May 27, 2019 I used a plastic sheet for my bag door. Spruce has it and I wanted to try it. I may try to make the lower side panels with it too. Your door turned out better than mine. I thought the material was thick enough to hide the clips that hold the panel in. It’s not. I can live with it but live and learn. Quote Link to comment Share on other sites More sharing options...
