PT20J Posted April 26, 2019 Report Posted April 26, 2019 On 4/24/2019 at 4:31 PM, gsxrpilot said: +1 for MyGoFlight $$$$ Gee, Paul, with such a beautiful panel, you should consider one of these to replace the cigar lighter USB. Lots of configurations - even available illuminated. http://www.truebluepowerusa.com/aviation-products/usb-charging-ports/ Skip Quote
Sime Posted April 27, 2019 Report Posted April 27, 2019 (edited) I also recommend the RAM mount. I have it on the pilot yoke of my '76F with an Ipad Mini 4. Rock solid. Edited April 27, 2019 by Sime Quote
gsxrpilot Posted April 27, 2019 Report Posted April 27, 2019 16 hours ago, PT20J said: Gee, Paul, with such a beautiful panel, you should consider one of these to replace the cigar lighter USB. Lots of configurations - even available illuminated. http://www.truebluepowerusa.com/aviation-products/usb-charging-ports/ I've thought about it and likely will at some point. I really haven't done the right side yet. But you're correct, the lighter plug is kinda ugly. Quote
Paul_Havelka Posted May 3, 2019 Report Posted May 3, 2019 On 4/23/2019 at 2:33 PM, Marauder said: What did you use to mount the ipad to the magic arm? Quote
rbridges Posted May 3, 2019 Report Posted May 3, 2019 On 4/27/2019 at 8:48 AM, gsxrpilot said: I've thought about it and likely will at some point. I really haven't done the right side yet. But you're correct, the lighter plug is kinda ugly. at least you have the usb-c in the audio panel. Thats a nice feature with the PMA450 series. 1 Quote
Miami_Mooniac Posted October 13, 2021 Report Posted October 13, 2021 For the ram mount, there is for cessna/piper, beechcraft,or pilatus yoke. Which yoke is most similar to m20e yoke? Quote
PT20J Posted October 13, 2021 Report Posted October 13, 2021 2 hours ago, Miami_Mooniac said: For the ram mount, there is for cessna/piper, beechcraft,or pilatus yoke. Which yoke is most similar to m20e yoke? I used this https://smile.amazon.com/gp/product/B01EB7D1NK/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1 Quote
JWJR Posted October 14, 2021 Report Posted October 14, 2021 I used this https://smile.amazon.com/gp/product/B01EB7D1NK/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1 I use this also. I have it attached above the compass. I just use an iPhone 10XR in a spring loaded phone mount that attaches to the ram ball. I can turn the phone to use it vertically or horizontally. It’s up high near the visors so usually out of the direct sunlight so it never overheats. I see the detail just fine as it’s close to my line of vision. I used the iPad mini however I forgot it at home a few times. So I tried my iphone and realized it works just as well as the iPad for my VFR flights. Sent from my iPhone using Tapatalk Quote
JWJR Posted October 14, 2021 Report Posted October 14, 2021 Here is a photo of it attached to the center post. The white phone case is a morphie that almost doubled battery life. It being white also keeps the phone from over heating. I use it with ForeFlight. Yes having up there throws the compass off a bit. Sent from my iPhone using Tapatalk Quote
midlifeflyer Posted October 14, 2021 Report Posted October 14, 2021 (edited) 13 hours ago, Miami_Mooniac said: For the ram mount, there is for cessna/piper, beechcraft,or pilatus yoke. Which yoke is most similar to m20e yoke? I use a standard RAM (shown way back in like the 5 or 6th post more than 2 years ago in Mooneys, Cessnas, Pipers... the cradle in the photo is the RAM Tab-Tite. I like the X-Grip a little better, but both are preset open for air circulation and the Tab-Tite might have a slight placement advantage. Edited October 14, 2021 by midlifeflyer Quote
